[Qgis-user] How to make a raster blocking other labels
Ludwig Kniprath
ludwig at kni-online.de
Mon Jul 21 08:41:17 PDT 2025
Hi Ann-Christin,
another possibility:
- Create a polygon-layer with feature(s) covering your raster-tiles
- Set it's Layer-Properties -> Symbology to "No Symbols"
- Check Layer-Properties -> Labels -> Placement -> Obstacles -> Features
act as obstacles
- Set Obstacle Settings:
Regards
Ludwig
Am 21.07.25 um 12:09 schrieb Ludwig Kniprath via QGIS-User:
> Hi Ann-Christin,
> if their number is not too high, you can use the label-toolbar to hide
> some of the unwanted labels manually:
> Note:
> QGis uses an "AuxiliaryLayer" attached to the labeled layer which
> stores the feature-individual label-settings within the QGis-project:
> Regards
> Ludwig
> Am 21.07.25 um 09:24 schrieb Ann-Christin Voss via QGIS-User:
>> Dear all,
>> Is there a way to mark a raster as a block for other labels, as it is
>> possible for vector layers? The raster is loaded as vrt and I don't
>> want to show any labels in the area of the raster.
>> I'm used to labels connected to the layer itself; therefore, if a
>> raster is stacked above vector layers, it should overlay also the
>> labels of all the layers lying underneath, but in QGIS the labels are
>> all gathered in the top position.
>> Thanks for any advice!
>> Best regards
>> Mit freundlichem Gruß
>> Ann-Christin Voss
>> Geodatenmanagerin
>> *AGIS Anwender-Geo-Informations-Systeme GmbH*
>> Im Atzelnest 3
>> 61352 Bad Homburg v. d. Höhe
>> Telefon:
>> +49 6172 59531 - 28
>> E-Mail:
>> _ann-christin.voss at geoas.de_
>> Internet:
>> _www.geoas.de <http://www.geoas.de/>_
>> Geschäftsführer Michael Jäger, Klaus Schacht, Handelsregister
>> Amtsgericht Bad Homburg v. d. Höhe HRB 15522, USt-IdNr. DE 114 115 374
>> GeoAS • MapInfo • FME • WebGIS • Mobiles GIS
>> QGIS-User mailing list
>> QGIS-User at lists.osgeo.org
>> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20250721/773c7224/attachment-0001.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20250721/773c7224/attachment-0001.png>
More information about the QGIS-User
