[Qgis-user] QGIS-User Digest, Vol 232, Issue 8
boxerg at iinet.net.au
Wed Jun 4 12:41:24 PDT 2025
Re: Alternate Network Install Option
When I try to select an alternate install location there is no option using
the express install and using the advanced install does not
download all the files. I have created a new folder called
>C:/PgmFiles>QGIS and attempted to install it there.
Anyone have any suggestions?
Regards Grant
-----Original Message-----
From: QGIS-User <qgis-user-bounces at lists.osgeo.org> On Behalf Of
qgis-user-request at lists.osgeo.org
Sent: Wednesday, 4 June 2025 5:00 AM
To: qgis-user at lists.osgeo.org
Subject: QGIS-User Digest, Vol 232, Issue 8
Send QGIS-User mailing list submissions to
To subscribe or unsubscribe via the World Wide Web, visit
https://lists.osgeo.org/mailman/listinfo/qgis-user
or, via email, send a message with subject or body 'help' to
You can reach the person managing the list at
qgis-user-owner at lists.osgeo.org
When replying, please edit your Subject line so it is more specific than
"Re: Contents of QGIS-User digest..."
Today's Topics:
1. OSGeo4W Install Location (boxerg at iinet.net.au)
2. Re: OSGeo4W Install Location (Johannes Kr?ger (WhereGroup))
3. Batch convert nonsense-coordinates from DWG? (Bernd Vogelgesang)
4. Re: Batch convert nonsense-coordinates from DWG?
(J?rgen E. Fischer)
5. Re: Batch convert nonsense-coordinates from DWG?
(mail at berndvogelgesang.de)
Message: 1
Date: Tue, 3 Jun 2025 16:12:54 +1000
To: <qgis-user at lists.osgeo.org>
Subject: [Qgis-user] OSGeo4W Install Location
Message-ID: <006701dbd44e$8b8246b0$a286d410$@iinet.net.au>
Content-Type: text/plain; charset="us-ascii"
Is there a way to install the OSGeo4W installer into another folder other
than the c: drive root directory? Installing into the C: drive root
directory causes problems in managed IT systems.
Regards Grant Boxer
URL:
<http://lists.osgeo.org/pipermail/qgis-user/attachments/20250603/72d0f437/at
tachment-0001.htm>
Message: 2
Date: Tue, 3 Jun 2025 08:46:16 +0200
From: Johannes Kr?ger (WhereGroup) <johannes.kroeger at wheregroup.com>
Subject: Re: [Qgis-user] OSGeo4W Install Location
Message-ID: <996717d7-f2c1-40c0-a446-c57eb02c9256 at wheregroup.com>
Content-Type: text/plain; charset="utf-8"; Format="flowed"
Hi Grant,
yes, you can choose a different installation location during the
installation process.
Cheers, Hannes
> other than the c: drive root directory? Installing into the C: drive
> root directory causes problems in managed IT systems.
> Regards Grant Boxer
> QGIS-User at lists.osgeo.org
> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
Johannes Kr?ger / GIS-Entwickler/-Berater
Schon gewusst?
In unserem Blog geben wir Tipps & Tricks zu Open-Source-GIS-Software und
berichten aus unserem Experten-Alltag:
https://wheregroup.com/blog/
WhereGroup GmbH
c/o KK03 GmbH
Lange Reihe 29
20099 Hamburg
Germany
Tel: +49 (0)228 / 90 90 38 - 36
Fax: +49 (0)228 / 90 90 38 - 11
www.wheregroup.com
Gesch?ftsf?hrer:
Olaf Knopp, Peter Stamm
Amtsgericht Bonn, HRB 9885
URL:
<http://lists.osgeo.org/pipermail/qgis-user/attachments/20250603/f22729a0/at
tachment-0001.htm>
Message: 3
Date: Tue, 3 Jun 2025 16:25:54 +0200
From: Bernd Vogelgesang <mail at berndvogelgesang.de>
To: qgis-user <qgis-user at lists.osgeo.org>
Subject: [Qgis-user] Batch convert nonsense-coordinates from DWG?
Message-ID: <27478089-6902-446f-aa83-b8ded7528cb0 at berndvogelgesang.de>
Content-Type: text/plain; charset=UTF-8; format=flowed
Hi there,
a friend received a DWG file which is (surprisingly) directly importable
into QGIS.
The problem is, that the CAD-guys use a very strange coordinate system.
Actually, the data should be in EPSG 25833, but somehow they managed to
scramble the x-values by adding 33 before the otherwise correct coordinates.
The imported DWG has 120 layer groups, most of them rubbish like always, but
to find out which layers are valuable, we would need to be able to display
them over aerial images beforehand!
Even if I knew a way to manually convert them one by one, I certainly would
die during the process.
Does anyone have an idea how to directly manipulate the geopackage created
during the import, e.g. with ogr commands in a bash script that loops over
the relevant tables?
This might be a solution not to destroy the otherwise usable layout created
during import.
Thankful for any insights,
Bernd
Dipl.-Geogr.
Bernd Vogelgesang
Kappel 17
91355 Hiltpoltstein
Tel: 09192-3499427
mobil: 0163-1860160
Message: 4
Date: Tue, 3 Jun 2025 17:10:28 +0200
Subject: Re: [Qgis-user] Batch convert nonsense-coordinates from DWG?
Message-ID: <20250603151028.sr2fd2v33lzp6bii at norbit.de>
Moin Bernd,
On Tue, 03. Jun 2025 at 16:25:54 +0200, Bernd Vogelgesang via QGIS-User
coordinates.
So EPSG:5650?
J?rgen
J?rgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
Dipl.-Inf. (FH) Rheinstra?e 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden https://www.norbit.de
QGIS release manager (PSC) Germany IRC: jef on Libera|OFTC
Desc: not available
URL:
<http://lists.osgeo.org/pipermail/qgis-user/attachments/20250603/04214a8d/at
tachment-0001.sig>
Message: 5
Date: Tue, 3 Jun 2025 20:31:02 +0200
Message-ID: <04b0faea-968e-4486-a87f-d402c5651c31 at berndvogelgesang.de>
So now I tried the import with EPSG 5653 and this one seems to work.
I am working now with geodata for around 15 years, but the CAD scene
never runs out of new obstacles for me.
What the f is EPSG 5653, and most importantly: Why is it it even being used?
(Fun fact: once a CAD guy told me, after me complaining about his data
having just some local cartesian coordinates and no official CRS, that
his software would run much slower, the higher the coordinate numbers
were, so working with short local coordinates was his way to be able to
work at all.
Now these other guys just add another 2 digits? Obviously trying to
evade work!)
Did I already mention that I very much dislike CAD and its seemlingly
not existing philosophy behind it.
Thanks for the hints!
Bernd
Am 03.06.25 um 17:10 schrieb J?rgen E. Fischer via QGIS-User:
> Moin Bernd,
coordinates.
> So EPSG:5650?
> J?rgen
Dipl.-Geogr.
Bernd Vogelgesang
Kappel 17
91355 Hiltpoltstein
Tel: 09192-3499427
mobil: 0163-1860160
Subject: Digest Footer
End of QGIS-User Digest, Vol 232, Issue 8
More information about the QGIS-User
