[Qgis-user] Voronoi issue
Andrew Harfoot
ajph at geodata.soton.ac.uk
Thu Jun 5 06:06:12 PDT 2025
Hi list,
I have encountered an issue when creating Voronoi polygons from a point
dataset using the native Voronoi polygons processing tool in QGIS
3.40.7. I'm not sure whether this is a bug or not, so am asking for an
opinion here before raising a ticket. I have attached an excerpt from a
larger point dataset which causes the voronoi tool to fail with an error:
Feature could not be written to
Voronoi_polygons_b838458f_b720_4604_8b19_e58370910ee7: Could not add
feature with geometry type GeometryCollection to layer of type Polygon
Could not write feature into OUTPUT
Execution failed after 0.03 seconds
As far as I can tell, there is nothing unusual about these points, and
they have come from a much larger dataset of 1.1 million points that all
complete successfully.
If I export the points to a GeoJSON with the default 15dp precision, the
error no longer arises, whereas increasing the precision to 20dp results
in the error still occurring, the difference being in rownum = 15.
I'd like to understand why the error is arising so as to avoid similar
issues in the future.
Cheers,
Andy
Andy Harfoot
GeoData Institute
University of Southampton
Southampton
SO17 1BJ
www.geodata.soton.ac.uk
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20250605/0b5bdd76/attachment.htm>
"type": "FeatureCollection",
"name": "SuspectPoints_20dp",
"crs": { "type": "name", "properties": { "name": "urn:ogc:def:crs:OGC:1.3:CRS84" } },
"xy_coordinate_resolution": 1e-20,
"features": [
{ "type": "Feature", "properties": { "rownum": 1 }, "geometry": { "type": "Point", "coordinates": [ -4.06625270109031067278, 10.91291423849551200931 ] } },
{ "type": "Feature", "properties": { "rownum": 2 }, "geometry": { "type": "Point", "coordinates": [ -4.0670860347665094281, 10.91291423849551200931 ] } },
{ "type": "Feature", "properties": { "rownum": 3 }, "geometry": { "type": "Point", "coordinates": [ -4.06541936741411191747, 10.91291423849551200931 ] } },
{ "type": "Feature", "properties": { "rownum": 4 }, "geometry": { "type": "Point", "coordinates": [ -4.06625270109031067278, 10.91458090611198095132 ] } },
{ "type": "Feature", "properties": { "rownum": 5 }, "geometry": { "type": "Point", "coordinates": [ -4.06625270109031067278, 10.91374757230374648032 ] } },
{ "type": "Feature", "properties": { "rownum": 6 }, "geometry": { "type": "Point", "coordinates": [ -4.06541936741411191747, 10.91374757230374648032 ] } },
{ "type": "Feature", "properties": { "rownum": 7 }, "geometry": { "type": "Point", "coordinates": [ -4.06541936741411191747, 10.91458090611198095132 ] } },
{ "type": "Feature", "properties": { "rownum": 8 }, "geometry": { "type": "Point", "coordinates": [ -4.06458603373791405033, 10.9124975715913947738 ] } },
{ "type": "Feature", "properties": { "rownum": 9 }, "geometry": { "type": "Point", "coordinates": [ -4.06458603373791405033, 10.91374757230374648032 ] } },
{ "type": "Feature", "properties": { "rownum": 10 }, "geometry": { "type": "Point", "coordinates": [ -4.06541936741411191747, 10.91083090397492405543 ] } },
{ "type": "Feature", "properties": { "rownum": 11 }, "geometry": { "type": "Point", "coordinates": [ -4.06541936741411191747, 10.90958090326257234892 ] } },
{ "type": "Feature", "properties": { "rownum": 12 }, "geometry": { "type": "Point", "coordinates": [ -4.06458603373791405033, 10.91124757087904129094 ] } },
{ "type": "Feature", "properties": { "rownum": 13 }, "geometry": { "type": "Point", "coordinates": [ -4.06708603476650853992, 10.91208090468727576194 ] } },
{ "type": "Feature", "properties": { "rownum": 14 }, "geometry": { "type": "Point", "coordinates": [ -4.06541936741411191747, 10.91208090468727576194 ] } },
{ "type": "Feature", "properties": { "rownum": 15 }, "geometry": { "type": "Point", "coordinates": [ -4.0637527000617161832, 10.91208090468727576194 ] } },
{ "type": "Feature", "properties": { "rownum": 16 }, "geometry": { "type": "Point", "coordinates": [ -4.06875270211890516237, 10.91291423849551023295 ] } },
{ "type": "Feature", "properties": { "rownum": 17 }, "geometry": { "type": "Point", "coordinates": [ -4.06875270211890516237, 10.91208090468727576194 ] } },
{ "type": "Feature", "properties": { "rownum": 18 }, "geometry": { "type": "Point", "coordinates": [ -4.0670860347665094281, 10.91374757230374648032 ] } },
{ "type": "Feature", "properties": { "rownum": 19 }, "geometry": { "type": "Point", "coordinates": [ -4.06875270211890516237, 10.91374757230374648032 ] } },
{ "type": "Feature", "properties": { "rownum": 20 }, "geometry": { "type": "Point", "coordinates": [ -4.0637527000617161832, 10.91124757087904129094 ] } },
{ "type": "Feature", "properties": { "rownum": 21 }, "geometry": { "type": "Point", "coordinates": [ -4.0637527000617161832, 10.90958090326257234892 ] } },
{ "type": "Feature", "properties": { "rownum": 22 }, "geometry": { "type": "Point", "coordinates": [ -4.0637527000617161832, 10.91041423707080681993 ] } }
"name": "SuspectPoints_15dp",
"features": [
{ "type": "Feature", "properties": { "rownum": 1 }, "geometry": { "type": "Point", "coordinates": [ -4.066252701090311, 10.912914238495512 ] } },
{ "type": "Feature", "properties": { "rownum": 2 }, "geometry": { "type": "Point", "coordinates": [ -4.067086034766509, 10.912914238495512 ] } },
{ "type": "Feature", "properties": { "rownum": 3 }, "geometry": { "type": "Point", "coordinates": [ -4.065419367414112, 10.912914238495512 ] } },
{ "type": "Feature", "properties": { "rownum": 4 }, "geometry": { "type": "Point", "coordinates": [ -4.066252701090311, 10.914580906111981 ] } },
{ "type": "Feature", "properties": { "rownum": 5 }, "geometry": { "type": "Point", "coordinates": [ -4.066252701090311, 10.913747572303746 ] } },
{ "type": "Feature", "properties": { "rownum": 6 }, "geometry": { "type": "Point", "coordinates": [ -4.065419367414112, 10.913747572303746 ] } },
{ "type": "Feature", "properties": { "rownum": 7 }, "geometry": { "type": "Point", "coordinates": [ -4.065419367414112, 10.914580906111981 ] } },
{ "type": "Feature", "properties": { "rownum": 8 }, "geometry": { "type": "Point", "coordinates": [ -4.064586033737914, 10.912497571591395 ] } },
{ "type": "Feature", "properties": { "rownum": 9 }, "geometry": { "type": "Point", "coordinates": [ -4.064586033737914, 10.913747572303746 ] } },
{ "type": "Feature", "properties": { "rownum": 10 }, "geometry": { "type": "Point", "coordinates": [ -4.065419367414112, 10.910830903974924 ] } },
{ "type": "Feature", "properties": { "rownum": 11 }, "geometry": { "type": "Point", "coordinates": [ -4.065419367414112, 10.909580903262572 ] } },
{ "type": "Feature", "properties": { "rownum": 12 }, "geometry": { "type": "Point", "coordinates": [ -4.064586033737914, 10.911247570879041 ] } },
{ "type": "Feature", "properties": { "rownum": 13 }, "geometry": { "type": "Point", "coordinates": [ -4.067086034766509, 10.912080904687276 ] } },
{ "type": "Feature", "properties": { "rownum": 14 }, "geometry": { "type": "Point", "coordinates": [ -4.065419367414112, 10.912080904687276 ] } },
{ "type": "Feature", "properties": { "rownum": 15 }, "geometry": { "type": "Point", "coordinates": [ -4.063752700061716, 10.912080904687276 ] } },
{ "type": "Feature", "properties": { "rownum": 16 }, "geometry": { "type": "Point", "coordinates": [ -4.068752702118905, 10.91291423849551 ] } },
{ "type": "Feature", "properties": { "rownum": 17 }, "geometry": { "type": "Point", "coordinates": [ -4.068752702118905, 10.912080904687276 ] } },
{ "type": "Feature", "properties": { "rownum": 18 }, "geometry": { "type": "Point", "coordinates": [ -4.067086034766509, 10.913747572303746 ] } },
{ "type": "Feature", "properties": { "rownum": 19 }, "geometry": { "type": "Point", "coordinates": [ -4.068752702118905, 10.913747572303746 ] } },
{ "type": "Feature", "properties": { "rownum": 20 }, "geometry": { "type": "Point", "coordinates": [ -4.063752700061716, 10.911247570879041 ] } },
{ "type": "Feature", "properties": { "rownum": 21 }, "geometry": { "type": "Point", "coordinates": [ -4.063752700061716, 10.909580903262572 ] } },
{ "type": "Feature", "properties": { "rownum": 22 }, "geometry": { "type": "Point", "coordinates": [ -4.063752700061716, 10.910414237070807 ] } }
More information about the QGIS-User
