[Qgis-user] Drawing circles on maps at 600 ft diameters out to 3000 feet from a specific point
    Brent Wood
    Brent.Wood at niwa.co.nz
    Wed Mar  5 19:43:02 PST 2025
The short answer is yes, QGIS can do that sort of stuff, but I'd use a different workflow which I think is easier.
If you have a spatially enabled database (Postgis, Spatialite, MySQL, MariaDB, etc), I'd do it there. Spatialite is probably the best to start with if you have not used one before.
Have a table with a point column for your points, add a polygon column for your 600ft circle, another for your 1200ft, etc,
Populate the columns by buffering the point with the appropriate radius (1/2 your circle diameter).
The quadrants can be generated several ways -eg:  ST_Project() will extend a line in a specified direction from a specified point, then clip those lines to each of the circles - and you have the quadrants.
Connect to the DB with QGIS, open the table and plot each of the columns as a separate QGIS map layer. Set the symbology of each circle to "no fill" or to mostly transparent. Make sure these layers are above your background/context layers.
Happy to help if you contact me off list.
Cheers
Brent Wood
Principal Technician, Fisheries
NIWA
DDI:  +64 (4) 3860529
From: QGIS-User <qgis-user-bounces at lists.osgeo.org> on behalf of Michael Walker via QGIS-User <qgis-user at lists.osgeo.org>
Sent: Wednesday, February 26, 2025 14:26
To: qgis-user at lists.osgeo.org <qgis-user at lists.osgeo.org>
Subject: [Qgis-user] Drawing circles on maps at 600 ft diameters out to 3000 feet from a specific point
I am new to this software mapping program and am interested in creating some maps with circles around specific points on the map at 600 feet intervals.  (600 feet, 1200 feet, 1800 feet, 2400 feet and 3000 feet)  I will need to be able to draw these circles without covering the
aerial view or topographical view features under them as well as draw lines disecting these circles into 4 quardrans.   Is this software able to perform these tasks??
Any help is greatly appreciated,
Thanks
Michael J. Walker
QGIS-User mailing list
QGIS-User at lists.osgeo.org
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user<https://lists.osgeo.org/mailman/listinfo/qgis-user>
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user<https://lists.osgeo.org/mailman/listinfo/qgis-user>
[https://www.niwa.co.nz/static/niwa-2018-horizontal-180.png] <https://www.niwa.co.nz/>
Brent Wood
Principal Technician - GIS and Spatial Data Management
Programme Leader - Environmental Information Delivery
+64-4-386-0529
National Institute of Water & Atmospheric Research Ltd (NIWA)
301 Evans Bay Parade Hataitai Wellington New Zealand
Connect with NIWA: niwa.co.nz<https://www.niwa.co.nz/> Facebook<https://www.facebook.com/nzniwa> LinkedIn<https://www.linkedin.com/company/niwa> Twitter<https://twitter.com/niwa_nz> Instagram<https://www.instagram.com/niwa_science> YouTube<https://www.youtube.com/channel/UCJ-j3MLMg1H59Ak2UaNLL3A>
To ensure compliance with legal requirements and to maintain cyber security standards, NIWA's IT systems are subject to ongoing monitoring, activity logging and auditing. This monitoring and auditing service may be provided by third parties. Such third parties can access information transmitted to, processed by and stored on NIWA's IT systems.
Note: This email is intended solely for the use of the addressee and may contain information that is confidential or subject to legal professional privilege. If you receive this email in error please immediately notify the sender and delete the email.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20250306/b745dd1d/attachment.htm>
More information about the QGIS-User
