[Qgis-user] Disable map update in Layout Editor?
    Prud'homme Jérémie
    p.jeremie at gmail.com
    Sun Mar  9 14:19:22 PDT 2025
What you are maybe looking for is this option that was available in QGIS
2.18 and 3.4 :
https://download.qgis.org/qgisdata/QGIS-Documentation-2.18/live/html/en/docs/user_manual/print_composer/composer_items/composer_map.html
Render mode : rectangle, cache, render.
Maybe it has been removed with the more powerful computer arising ?
Best Regards,
Jérémie.
Le dim. 9 mars 2025 à 21:49, Tobias Schula via QGIS-User <
qgis-user at lists.osgeo.org> a écrit :
> Hi Em
> > On Mon, 3 Mar 2025 at 20:32, Tobias Schula via QGIS-User <
> > > is it possible to disable the updating of maps in the layout editor,
> once
> > > I
> > > have set scale and extend?
> Am Dienstag, 4. März 2025, 21:34 schrieb Emma Hain:
> > Please correct me if I am wrong but by clicking `Lock Layers` this may
> work
> > for you.
> https://docs.qgis.org/3.40/en/docs/user_manual/print_composer/composer_items
> > /composer_map.html#layers
> Thanks for your reply. Unfortunately, that is not a solution for my
> problem.
> When I wrote "updating" I meant "refreshing". I just tested it again. I
> have a
> layout with 12 pages and 33 different maps, each showing a different view
> of my
> mapping project. The individual maps show 3 different map themes.
> Switching
> from map themes to lock layers doesn't change the outcome.
> Just opening this layout freezes QGIS for more than 5 minutes. Just
> scrolling
> through the 12 pages is glacially slow, moving an item is choppy, I need
> to
> select it and press the mouse button for half a minute before I can start
> to
> move it. Then another scroll or zoom in the layout will cause another
> refresh
> and another long wait.
> So far I haven't found a way to turn of the refresh. It would be
> sufficient for
> QGIS to just cache a static low resolution image of the individual map's
> content and only refresh it, when I change the view or manually refresh.
> In
> it's current state it's unusable for me and I need to come up with a
> workaround for my upcoming 10 similar projects.
> Best regards
> Toby
> Tobias A Schula
> Forestry Expert
> geospatial at schula.org
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20250309/194c3378/attachment.htm>
More information about the QGIS-User
