[Qgis-user] Remote Access by Multiple Users
Tobias Schula geospatial at schula.org
Wed Mar 19 02:30:59 PDT 2025
On Wednesday, 19 March 2025, 10:10:20 CET Stewart Galloway via QGIS-User
wrote:
> I have data stored on a municipal server.Can I have two users, each on their
> own computer, access the same .QGS project file (as well as the same data
> on the municipal server)?
How is the data stored? Is it in a database already? Is it in a GDB from
ArcGIS, is it a folder of shapefiles? If it's already in a database, there are
spatial extensions for quite a few of them, alternatively, you can always
store the geometry data as WKB or WKT in a 'geometry' column.
If it's in some ESRI/ArcGIS database or a folder of shapefiles, don't touch
it, these formats are not made for network access and you will eventually
corrupt all the data!
> Is that what a GeoPackage is for?  Or is
> Geopackage just for the data and not for the project file (QGS)? Or do I
> use PostgreSQL?
Geopackage is built on top of SQLite, a *single* user, embedded database,
similar to Spatialite, but with a different scope. It is very well suited for
data exchange, a million times better than shape files. It is mainly for
storing the data, but you can save the QGIS project file as an extra layer/
table in the database. I use that, when I want to give customers a cleaned up
QGIS project with all their data in it. You just drag and drop the single
geopackage into QGIS and the whole project will load with all styles and
calculations.
I've used it on projects where I was the only one digitizing and editing.
Multiple users can access it simultaneously, but then it should be read only.
You can also split up areas in work packages, the 2 users work on it at the
same time, can see the updates of the other and when you're done, you join the
layers again.
But, seriously, that is all a crutch. One small mistake and the work of hours
is gone or, even worse, the whole geopackage is corrupted. For this use case
you really really want a multi user, relational database with versioning.
Fortunately, we already have that, it's PostgreSQL with the PostGIS extension!
Talk to your IT have them set it up for you. If they complain, talk to their
superior, show them how much money the organization could potentially lose if
you waste one workday of two employees.
Best regards
Tobias A Schula
Forestry Expert
Desc: This is a digitally signed message part.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20250319/bcef3002/attachment.sig>
More information about the QGIS-User mailing list
