[Qgis-user] Remote Access by Multiple Users
Emma Hain emma at north-road.com
Wed Mar 19 17:01:17 PDT 2025
In a previous job, when we didn't use postgres, I would create the template
QGS (with all the styles, print layouts & etc ) and generally have the data
as ArcGIS Rest Servers, WFS OR a discipline specific gpkg that was only
read that once they copied, they could edit. I had this set up for each
discipline (geology, water, environment & etc).
It meant they were starting with the base project and data and they could
do with it as they wanted.
But if you want to build onto the data, I would probably look at Kart
<https://kartproject.org/>possibly along with postGIS.
Kind regards
Em
Emma Hain — Product Manager/Senior GIS Analyst
[image: https://north-road.com]
*North Road*
Cartography • Development • Spatial Analysis
*north-road.com* <http://north-road.com>
<https://twitter.com/northroadgeo>
<https://www.linkedin.com/company/north-road-studios>
<https://www.facebook.com/North-Road-997236690392419/home>
QGIS User Conference 2025 <https://uc2025.qgis.org/>
2-3 June, Norrköping, Sweden
FOSS4G 2025 <https://2025.foss4g.org/>
17-23 November, Auckland, New Zealand
On Thu, 20 Mar 2025 at 08:25, Tobias Schula via QGIS-User <
qgis-user at lists.osgeo.org> wrote:
> On Wednesday, 19 March 2025, 23:05:47 CET Greg Troxel via QGIS-User wrote:
> > It sounds like
> >   When multiple people are using the same project file, whether via
> >   pgsql or a shared filesystem, they need to have a plan for performing
> >   writes to that project file, because there is no mechanism for merges
> >   or handling conflicts.
> > is the general statement then.
> This worked for me in the past:
> Create a _template_ project with all your styles, database connections,
> links,
> color ramps, scripts, etc. and hand it out to the users or install it for
> them. Then they can all access the same data, have the same styles and so
> on,
> but their project gets saved on their local machine. This is also a great
> fallback, if somebody messes up their project beyond repair.
> Still, it's a bit messy, because file paths might get broken and everyone
> has
> to re-authenticate with the database. You will also get a lot of warnings
> about missing fonts, because until recently, QGIS would default to
> different
> fonts on windows macos and linux.
> As far as I know, there is no solution for seamless access by everyone,
> it's
> all quirky.
> Tobias A Schula
> Forestry Expert
> geospatial at schula.org_______________________________________________
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20250320/1c1ddaba/attachment.htm>
More information about the QGIS-User mailing list
