[Qgis-user] Remote Access by Multiple Users
Saber Razmjooei saber.razmjooei at lutraconsulting.co.uk
Thu Mar 20 01:35:46 PDT 2025
You can use GeoPackage for multi-editing but not directly. GeoDiff (
https://github.com/MerginMaps/geodiff) is a low level library to handle the
changes. Mergin Maps is a platform built around that. You can install the
QGIS plugin and then users can make changes to the files and sync the data.
The added benefit is that you can version your data and see the full change
history.
Kind regards
Saber
On Thu, 20 Mar 2025 at 01:01, Emma Hain via QGIS-User <
qgis-user at lists.osgeo.org> wrote:
> In a previous job, when we didn't use postgres, I would create the
> template QGS (with all the styles, print layouts & etc ) and generally have
> the data as ArcGIS Rest Servers, WFS OR a discipline specific gpkg that was
> only read that once they copied, they could edit. I had this set up for
> each discipline (geology, water, environment & etc).
> It meant they were starting with the base project and data and they could
> do with it as they wanted.
> But if you want to build onto the data, I would probably look at Kart
> <https://kartproject.org/>possibly along with postGIS.
> Kind regards
> Em
> Emma Hain — Product Manager/Senior GIS Analyst
> emma at north-road.com
> [image: https://north-road.com]
> *North Road*
> Cartography • Development • Spatial Analysis
> *north-road.com* <http://north-road.com>
> <https://twitter.com/northroadgeo>
> <https://www.linkedin.com/company/north-road-studios>
> <https://www.facebook.com/North-Road-997236690392419/home>
> QGIS User Conference 2025 <https://uc2025.qgis.org/>
> 2-3 June, Norrköping, Sweden
> FOSS4G 2025 <https://2025.foss4g.org/>
> 17-23 November, Auckland, New Zealand
> On Thu, 20 Mar 2025 at 08:25, Tobias Schula via QGIS-User <
>> On Wednesday, 19 March 2025, 23:05:47 CET Greg Troxel via QGIS-User wrote:
>> > It sounds like
>> >   When multiple people are using the same project file, whether via
>> >   pgsql or a shared filesystem, they need to have a plan for performing
>> >   writes to that project file, because there is no mechanism for merges
>> >   or handling conflicts.
>> > is the general statement then.
>> This worked for me in the past:
>> Create a _template_ project with all your styles, database connections,
>> links,
>> color ramps, scripts, etc. and hand it out to the users or install it for
>> them. Then they can all access the same data, have the same styles and so
>> on,
>> but their project gets saved on their local machine. This is also a great
>> fallback, if somebody messes up their project beyond repair.
>> Still, it's a bit messy, because file paths might get broken and everyone
>> has
>> to re-authenticate with the database. You will also get a lot of warnings
>> about missing fonts, because until recently, QGIS would default to
>> different
>> fonts on windows macos and linux.
>> As far as I know, there is no solution for seamless access by everyone,
>> it's
>> all quirky.
>> Tobias A Schula
>> Forestry Expert
>> geospatial at schula.org_______________________________________________
>> QGIS-User mailing list
>> QGIS-User at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
Saber Razmjooei
CO-Founder
 [image: https://www.linkedin.com/in/saber-razmjooei/]
<https://www.linkedin.com/in/saber-razmjooei/>
<https://www.youtube.com/@LutraConsulting>
<https://github.com/lutraconsulting>
<https://www.lutraconsulting.co.uk/>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20250320/6065ce29/attachment.htm>
More information about the QGIS-User mailing list
