[Qgis-user] QGIS 3.40.4 LTS query bug in GDAL/vzip - errors in create virtual raster... and merge... processes
Andrea Giudiceandrea andreaerdna at libero.it
Fri Mar 21 10:47:22 PDT 2025
Hi Nickn,
after you have made sure that the problem also occurs using a new user
profile,
the best way to check what's going wrong is to provide a full
reproducible example, including a QGIS project file (if needed) sample
layer(s), relevant parameters used and step-by-step instructions.
Since you say the issue occurs on multiple different systems (both
Windows and Linux) and that it didn't occur using previous versions, I
think the straightforward way to do so is to open an issue report
providing all the requested info and also indicating which previous QGIS
version (including the GDAL/OGR version) the issue did not occur with
and which current QGIS versions (including the GDAL/OGR version) the
issue does occur.
Regards.
> nickn2004-qgis at yahoo.com nickn2004-qgis at yahoo.com
> Fri Mar 21 05:53:01 PDT 2025
> My problem is with QGIS 3.40.4 under Windows and Linux (Xubuntu).
> The Raster \ Miscellaneous \ Create virtual raster and the Merge processes both fail in both OSs. See the Stackexchange page:https://gis.stackexchange.com/questions/491275/gdal-vzip-failure-in-qgis-3-40-4-lts-osgeo4w
More information about the QGIS-User mailing list
