[Qgis-user] Ubuntu LTS 22.04 installation problem
    Antonio Viscomi
    antoviscomi at gmail.com
    Sun Mar 23 15:59:39 PDT 2025
Hi all, here is a workaround  in order to fix libpdal issue
https://github.com/qgis/QGIS/issues/52433#issuecomment-1792285094
Il gio 13 mar 2025, 10:55 Ian Turton via QGIS-User <
qgis-user at lists.osgeo.org> ha scritto:
> What does `apt-cache show libpdal-base13` show? you should see something
> like this:
> Package: libpdal-base13
> Status: install ok installed
> Priority: optional
> Section: libs
> Installed-Size: 5681
> Maintainer: Angelos Tzotsos <gcpp.kalxas at gmail.com>
> Architecture: amd64
> Source: pdal
> Version: 2.5.0+ds-1~jammy3
> Depends: libc6 (>= 2.34), libcurl4 (>= 7.16.2), libgcc-s1 (>= 3.3.1),
> libgdal34 (>= 3.7.0), libgeotiff5 (>= 1.4.3), libpdal-util13 (>= 2.5.0),
> libssl3 (>= 3.0.0~~alpha1), libstdc++6 (>= 12), libxml2 (>= 2.7.4),
> libzstd1 (>= 1.4.0), zlib1g (>= 1:1.1.4)
> Recommends: libpdal-plugins
> I suspect that there is some problem with the source of your GDAL
> conflicting with QGis - on my machine `libpdal_base.so.13` is a symlink to
> `libpdal_base.so.15.0.0` you can check with `ls -l /usr/lib/libpdal_base*`
> which should show something like:
> lrwxrwxrwx 1 root root      22 Jan  3 09:51 /usr/lib/libpdal_base.so.13 ->
> lrwxrwxrwx 1 root root      22 Jan 26  2024 /usr/lib/libpdal_base.so.15 ->
> -rw-r--r-- 1 root root 5511800 Jan 26  2024 /usr/lib/libpdal_base.so.15.0.0
> If 13 doesn't exist you can create it
> Ian
> On Thu, 13 Mar 2025 at 00:51, Alvaro Manrique via QGIS-User <
> qgis-user at lists.osgeo.org> wrote:
>> Hello everyone,
>> I'm having issues installing the latest QGIS version:
>> alvaromanrique at alvaromanrique-Crosshair-17-C12VF:~$ sudo apt upgrade
>> Reading package lists... Done
>> Building dependency tree... Done
>> Reading state information... Done
>> Calculating upgrade... Done
>> Get more security updates through Ubuntu Pro with 'esm-apps' enabled:
>>   python3-jupyter-core libde265-dev libheif1 imagemagick libjs-jquery-ui
>>   libopenexr-dev libavdevice58 ffmpeg libopenexr25 python3-scipy
>> libpostproc55
>>   libmagickcore-6.q16-6-extra libswscale-dev libavcodec58
>>   libmagickwand-6.q16-6 libavutil56 imagemagick-6.q16 libswscale5
>> libheif-dev
>>   libmagickcore-6.q16-6 libavutil-dev libgsl27 libswresample3
>>   imagemagick-6-common libavformat58 libgslcblas0 libavformat-dev
>>   libavcodec-dev libde265-0 libpmix2 libswresample-dev libavfilter7
>> Learn more about Ubuntu Pro at https://ubuntu.com/pro
>> The following packages have been kept back:
>>   grass-core
>> 0 to upgrade, 0 to newly install, 0 to remove and 1 not to upgrade.
>> 4 not fully installed or removed.
>> After this operation, 0 B of additional disk space will be used.
>> Do you want to continue? [Y/n] y
>> Setting up qgis-providers (1:3.40.3+36jammy) ...
>> /usr/lib/qgis/crssync: error while loading shared libraries:
>> libpdal_base.so.13: cannot open shared object file: No such file or
>> directory
>> dpkg: error processing package qgis-providers (--configure):
>>  installed qgis-providers package post-installation script subprocess
>> returned error exit status 127
>> dpkg: dependency problems prevent configuration of qgis:
>>  qgis depends on qgis-providers (= 1:3.40.3+36jammy); however:
>>   Package qgis-providers is not configured yet.
>> dpkg: error processing package qgis (--configure):
>>  dependency problems - leaving unconfigured
>> dpkg: dependency problems prevent configuration of qgis-plugin-grass:
>>  qgis-plugin-grass depends on qgis (= 1:3.40.3+36jammy); however:
>>   Package qgis is not configured yet.
>> dpkg: error processing package qgis-plugin-grass (--configure):
>> dpkg: dependency problems prevent configuration of python3-qgis:
>>  python3-qgis depends on qgis-providers (= 1:3.40.3+36jammy); however:
>> dpkg: error processing package python3-qgis (--configureNo apport report
>> written because the error message indicates it's a follow-up error from a
>> previous failure.
>>               No apport report written because the error mess
>> age indicates it's a follow-up error from a previous failure.
>>                                                              No apport
>> report written because MaxReports has already been reached
>> Errors were encountered while processing:
>>  qgis-providers
>>  qgis
>>  qgis-plugin-grass
>>  python3-qgis
>> E: Sub-process /usr/bin/dpkg returned an error code (1)
>> Can you help me with this?
>> Best wishes.
>> Alvaro MANRIQUE Jiménez
>> CIP: 01165409
>> DNI: 71252717
>> QGIS-User mailing list
>> QGIS-User at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> Ian Turton
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20250323/a328d3a5/attachment.htm>
More information about the QGIS-User
