[Qgis-user] MVP solid 3d
Gerald Kogler geraldo at servus.at
Thu Mar 13 11:39:18 PDT 2025
Hi!
I'm trying without success to visualize a simple solid 3d object with
QGIS 3d Map View. The geometry is of type PolygonZ, but the 3d viewer
only shows it in 2 dimensions without Z values. All triangles are shown
on a plain.
The layer definitly does have Z values, using for example
geom_to_wkt($geometry) does show me WKT values like:
PolygonZ ((204594.00012206999235786 496779.0001220700214617 2998679.5,
204771.00012206999235786 496783.0001220700214617 2998679.5,
204881.00012206999235786 496802.0001220700214617 2998679.5,
204594.00012206999235786 496779.0001220700214617 2998679.5))
What do I miss, anything in the configuration which could be wrong? I
only manage to show the third dimension using extruding, that works fine
for example to show buildings from OpenStreetMaps.
Anybody knows about a dummy Getting Started tutorial beside the official
QGIS docs about 3d Map View in order to make a really basic example work?
Thanks for your help
Gerald
More information about the QGIS-User mailing list
