[Qgis-user] MVP solid 3d
Johannes Kröger (WhereGroup)
johannes.kroeger at wheregroup.com
Fri Mar 14 01:17:54 PDT 2025
Hi Gerald,
a PolygonZ is not a solid but a surface* that might be rotated in 3D space.
Your PolygonZ has the same Z coordinate for all its points so it is
flat/orthogonal in reference to the vertical axis.
*: Depending on the Z coordinates a PolygonZ might not be a flat
(potentially rotated) surface but a rather complex surface. E.g. if you
have a polygon with 4 corners of which three have the same Z coordinate
but one has a different one: There is no flat surface connecting all
those points. I don't know the correct term for this right now.
Geometries like that are usually problematic. But
https://gis.stackexchange.com/a/350117/51035 shows an example with such
geometry being rendered "fine" in the QGIS 3D view.
Cheers, Hannes
On 3/13/25 19:39, Gerald Kogler via QGIS-User wrote:
> Hi!
> I'm trying without success to visualize a simple solid 3d object with
> QGIS 3d Map View. The geometry is of type PolygonZ, but the 3d viewer
> only shows it in 2 dimensions without Z values. All triangles are
> shown on a plain.
> The layer definitly does have Z values, using for example
> geom_to_wkt($geometry) does show me WKT values like:
> PolygonZ ((204594.00012206999235786 496779.0001220700214617 2998679.5,
> 204771.00012206999235786 496783.0001220700214617 2998679.5,
> 204881.00012206999235786 496802.0001220700214617 2998679.5,
> 204594.00012206999235786 496779.0001220700214617 2998679.5))
> What do I miss, anything in the configuration which could be wrong? I
> only manage to show the third dimension using extruding, that works
> fine for example to show buildings from OpenStreetMaps.
> Anybody knows about a dummy Getting Started tutorial beside the
> official QGIS docs about 3d Map View in order to make a really basic
> example work?
> Thanks for your help
> Gerald
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
Johannes Kröger / GIS-Entwickler/-Berater
FOSSGIS Konferenz 2025 in Münster
26.-29. März 2025
https://www.fossgis.de/konferenz/
WhereGroup GmbH
c/o KK03 GmbH
Lange Reihe 29
20099 Hamburg
Germany
Tel: +49 (0)228 / 90 90 38 - 36
Fax: +49 (0)228 / 90 90 38 - 11
www.wheregroup.com
Geschäftsführer:
Olaf Knopp, Peter Stamm
Amtsgericht Bonn, HRB 9885
More information about the QGIS-User
