[Qgis-user] MVP solid 3d
Gerald Kogler geraldo at servus.at
Fri Mar 14 11:57:39 PDT 2025
Thanks for your answers and the hint with flat Z coordinate. Now I
managed to have MultiPolygonZ geometries with the complete 3d object
saved as feature.
Here a sample layer as gpkg file [1] containing 64 objects from an
arqueological excavation.
Objects do show up as plains in 3d Map View (QGIS 3.34), when I apply a
Single Symbol in 3D View Properties, they do disappear so.
Thanks for your help
Gerald
[1] https://cloud.servus.at/s/Gigik6fAYZKGjib
On 14/3/25 9:17, Johannes Kröger (WhereGroup) via QGIS-User wrote:
> Hi Gerald,
> a PolygonZ is not a solid but a surface* that might be rotated in 3D space.
> Your PolygonZ has the same Z coordinate for all its points so it is
> flat/orthogonal in reference to the vertical axis.
> *: Depending on the Z coordinates a PolygonZ might not be a flat
> (potentially rotated) surface but a rather complex surface. E.g. if you
> have a polygon with 4 corners of which three have the same Z coordinate
> but one has a different one: There is no flat surface connecting all
> those points.  I don't know the correct term for this right now.
> Geometries like that are usually problematic. But https://
> gis.stackexchange.com/a/350117/51035 shows an example with such geometry
> being rendered "fine" in the QGIS 3D view.
> Cheers, Hannes
> On 3/13/25 19:39, Gerald Kogler via QGIS-User wrote:
>> Hi!
>> I'm trying without success to visualize a simple solid 3d object with
>> QGIS 3d Map View. The geometry is of type PolygonZ, but the 3d viewer
>> only shows it in 2 dimensions without Z values. All triangles are
>> shown on a plain.
>> The layer definitly does have Z values, using for example
>> geom_to_wkt($geometry) does show me WKT values like:
>> PolygonZ ((204594.00012206999235786 496779.0001220700214617 2998679.5,
>> 204771.00012206999235786 496783.0001220700214617 2998679.5,
>> 204881.00012206999235786 496802.0001220700214617 2998679.5,
>> 204594.00012206999235786 496779.0001220700214617 2998679.5))
>> What do I miss, anything in the configuration which could be wrong? I
>> only manage to show the third dimension using extruding, that works
>> fine for example to show buildings from OpenStreetMaps.
>> Anybody knows about a dummy Getting Started tutorial beside the
>> official QGIS docs about 3d Map View in order to make a really basic
>> example work?
>> Gerald
>> QGIS-User mailing list
>> QGIS-User at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
More information about the QGIS-User mailing list
