[Qgis-user] MVP solid 3d
    Benoit D.-M.
    benoit.de.mezzo at oslandia.com
    Wed Mar 26 03:12:13 PDT 2025
For what I have tried with your data, the Z coordinates have a really
high value (around 2999675) (is it not a bit strange for arqueological
excavation data?) and it seems QGIS does not like these high values (and
it may need a fix).
So I have tried by decreasing 2990000 on all Z data and it works fine!
Regards.
Le 19/03/2025 à 11:29, Gerald Kogler via QGIS-User a écrit :
> Hi ppl,
> Still no success with that :(
> Anybody could share me a simple MultiPolygonZ object for QGIS which
> does work in 3d Map View configuring the Single Symbol in 3D View
> Properties? Just to make sure that it's not the installation or
> configuration of my QGIS.
> Thanks
> Gerald
> On 14/3/25 19:57, Gerald Kogler via QGIS-User wrote:
>> Hi,
>> Thanks for your answers and the hint with flat Z coordinate. Now I
>> managed to have MultiPolygonZ geometries with the complete 3d object
>> saved as feature.
>> Here a sample layer as gpkg file [1] containing 64 objects from an
>> arqueological excavation.
>> Objects do show up as plains in 3d Map View (QGIS 3.34), when I apply
>> a Single Symbol in 3D View Properties, they do disappear so.
>> Thanks for your help
>> Gerald
>> [1] https://cloud.servus.at/s/Gigik6fAYZKGjib
>> On 14/3/25 9:17, Johannes Kröger (WhereGroup) via QGIS-User wrote:
>>> Hi Gerald,
>>> a PolygonZ is not a solid but a surface* that might be rotated in 3D
>>> space.
>>> Your PolygonZ has the same Z coordinate for all its points so it is
>>> flat/orthogonal in reference to the vertical axis.
>>> *: Depending on the Z coordinates a PolygonZ might not be a flat
>>> (potentially rotated) surface but a rather complex surface. E.g. if
>>> you have a polygon with 4 corners of which three have the same Z
>>> coordinate but one has a different one: There is no flat surface
>>> connecting all those points.  I don't know the correct term for this
>>> right now. Geometries like that are usually problematic. But
>>> https:// gis.stackexchange.com/a/350117/51035 shows an example with
>>> such geometry being rendered "fine" in the QGIS 3D view.
>>> Cheers, Hannes
>>> On 3/13/25 19:39, Gerald Kogler via QGIS-User wrote:
>>>> Hi!
>>>> I'm trying without success to visualize a simple solid 3d object
>>>> with QGIS 3d Map View. The geometry is of type PolygonZ, but the 3d
>>>> viewer only shows it in 2 dimensions without Z values. All
>>>> triangles are shown on a plain.
>>>> The layer definitly does have Z values, using for example
>>>> geom_to_wkt($geometry) does show me WKT values like:
>>>> PolygonZ ((204594.00012206999235786 496779.0001220700214617
>>>> 2998679.5, 204771.00012206999235786 496783.0001220700214617
>>>> 2998679.5, 204881.00012206999235786 496802.0001220700214617
>>>> 2998679.5, 204594.00012206999235786 496779.0001220700214617
>>>> 2998679.5))
>>>> What do I miss, anything in the configuration which could be wrong?
>>>> I only manage to show the third dimension using extruding, that
>>>> works fine for example to show buildings from OpenStreetMaps.
>>>> Anybody knows about a dummy Getting Started tutorial beside the
>>>> official QGIS docs about 3d Map View in order to make a really
>>>> basic example work?
>>>> Gerald
>>>> _______________________________________________
>>>> QGIS-User mailing list
>>>> QGIS-User at lists.osgeo.org
>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
More information about the QGIS-User
