[Qgis-user] Incompatibility issue (QGIS Munster 3.42.1)
Andreas Neumann andreas at qgis.org
Fri Mar 28 09:59:39 PDT 2025
Hi Garry fox,
That case sounds to me that you should file a ticket with VMWare, not with
QGIS. Obviously the upgrade of VMWare introduced your issue.
Also: do you just get an OpenGL error message or is QGIS failing to work
inside the new VMWare? Are you using anything OpenGL related inside QGIS?
Greetings,
Andreas
On Thu, 27 Mar 2025 at 11:22, Penafiel, Garry Fox via QGIS-User <
qgis-user at lists.osgeo.org> wrote:
> Hi,
> Good day!
> I would like to raise a request regarding the compatibility test for QGIS
> 3.42.1. During testing, I encountered an issue related to a graphics driver
> or OpenGL error.
> I am using a VMware device with VMware Tools version 12.5, and I found
> that the latest QGIS is not compatible with the latest version of VMware
> Tools. To resolve the issue, I downgraded VMware Tools, and that fixed
> it.Do you have any workaround or configuration to make the latest QGIS work
> with the latest VMware Tools?
> Thank you.
> Best Regards,
> *Garry fox Peñafiel*
> Application Packaging Specialist
> garryfox.penafiel at bauer.net.ph
> www.bauer.net.ph
> BAUER Foundations Philippines Inc., 12th Floor Units A-K,
> Cyber One Building, 11 Eastwood Avenue, Eastwood City Cyberpark,
> Bagumbayan, Quezon City 1110 Metro Manila
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
Andreas Neumann
QGIS.ORG board member (treasurer)
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20250328/21e00e93/attachment.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20250328/21e00e93/attachment.png>
More information about the QGIS-User mailing list
