[Qgis-user] FW: "Phantom" point in created layer
    Nora Badenhorst
    norabadenhorst at nova.org.za
    Sun Mar 30 23:29:12 PDT 2025
Hi Randy,
I used the “Add point” feature.
It is not stacked because the “phantom” points are all at the same location somewhere in the ocean.
[cid:image004.png at 01DBA216.F64F6460]
Regards
Nôra Badenhorst
RESEARCH ASSISTANT AND OFFICE ADMINISTRATOR
nôrabadenhorst at nova.org.za<mailto:n%C3%B4rabadenhorst at nova.org.za>
+27 (0) 72 146 3633
Office 1, Aura Aesta Building, 2 Witteboom Street, Hartenbos 6520
nova.org.za<https://nova.org.za/>
Quality of life
begins at home
[Nova Institute Logo]
From: QGIS-User <qgis-user-bounces at lists.osgeo.org> On Behalf Of Randal Hale via QGIS-User
Sent: Wednesday, 26 March 2025 14:50
To: qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] FW: "Phantom" point in created layer
Good morning Nora (or afternoon) ,
I'm wondering if you select (draw a polygon using the select tool) around one or two points you might select 2 or 4 points - you may have points stacked accidentally.
Randy
On 3/26/25 02:14, Nora Badenhorst via QGIS-User wrote:
Hallo Chris,
Hope you are well??
Thanks for the reply.
Why are you using "Add polygon feature" when your goal appears to be adding points?
Sorry, I now realised that I wrote “polygon feature”. I actually use “Add point feature”
[cid:image002.png at 01DBA216.567F86E0]
What is the geometry of your shapefile layer?  If you intend to have points in it, then the geometry should be "point".
The geometry is Point.
[cid:image003.png at 01DBA216.567F86E0]
Regards
Nôra Badenhorst
+27 (0) 72 146 3633
Quality of life
begins at home
From: chris hermansen <clhermansen at gmail.com><mailto:clhermansen at gmail.com>
Sent: Tuesday, 25 March 2025 17:42
To: Nora Badenhorst <norabadenhorst at nova.org.za><mailto:norabadenhorst at nova.org.za>
Cc: qgis-user at lists.osgeo.org<mailto:qgis-user at lists.osgeo.org>
Nora and list,
On Tue, Mar 25, 2025 at 12:05 PM Nora Badenhorst via QGIS-User <qgis-user at lists.osgeo.org<mailto:qgis-user at lists.osgeo.org>> wrote:
I am counting informal structures in our project areas.
I created a shapefile layer and use the “Toggle editing – Add polygon feature”  function to add a point. Every structure gets a dot.
Chris Hermansen · clhermansen "at" gmail "dot" com
C'est ma façon de parler.
QGIS-User mailing list
QGIS-User at lists.osgeo.org<mailto:QGIS-User at lists.osgeo.org>
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
Randal Hale
North Rivergeographic Systems, Inc
https://www.northrivergeographic.com
https://www.qgis-us.org
I hope this email finds you in the mountains, and as sun peeps through the trees the squirrels begin foraging.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20250331/0bd17ec5/attachment-0001.htm>
Type: image/png
Desc: image001.png
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20250331/0bd17ec5/attachment-0004.png>
Type: image/png
Desc: image002.png
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20250331/0bd17ec5/attachment-0005.png>
Type: image/png
Desc: image003.png
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20250331/0bd17ec5/attachment-0006.png>
Type: image/png
Desc: image004.png
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20250331/0bd17ec5/attachment-0007.png>
More information about the QGIS-User
