[Qgis-user] FW: "Phantom" point in created layer
Randal Hale rjhale at northrivergeographic.com
Wed Mar 26 05:49:46 PDT 2025
Good morning Nora (or afternoon) ,
I'm wondering if you select (draw a polygon using the select tool)
around one or two points you might select 2 or 4 points - you may have
points stacked accidentally.
Randy
On 3/26/25 02:14, Nora Badenhorst via QGIS-User wrote:
> Hallo Chris,
> Hope you are well??
> Thanks for the reply.
> /Why are you using "Add polygon feature" when your goal appears to be
> adding points?/
> Sorry, I now realised that I wrote “polygon feature”. I actually use
> “Add point feature”
> /What is the geometry of your shapefile layer?  If you intend to have
> points in it, then the geometry should be "point"./
> The geometry is Point.
> Regards
> *Nôra Badenhorst*
> RESEARCH ASSISTANT AND OFFICE ADMINISTRATOR
> nôrabadenhorst at nova.org.za <mailto:n%C3%B4rabadenhorst at nova.org.za>
> +27 (0) 72 146 3633
> Office 1, Aura Aesta Building, 2 Witteboom Street, Hartenbos 6520
> *nova.org.za* <https://nova.org.za/>
> Quality of life
> begins at home
> Nova Institute Logo
> *From:*chris hermansen <clhermansen at gmail.com>
> *Sent:* Tuesday, 25 March 2025 17:42
> *To:* Nora Badenhorst <norabadenhorst at nova.org.za>
> *Cc:* qgis-user at lists.osgeo.org
> *Subject:* Re: [Qgis-user] FW: "Phantom" point in created layer
> Nora and list,
> On Tue, Mar 25, 2025 at 12:05 PM Nora Badenhorst via QGIS-User
> <qgis-user at lists.osgeo.org> wrote:
>     I am counting informal structures in our project areas.
>     I created a shapefile layer and use the “Toggle editing – Add
>     polygon feature”  function to add a point. Every structure gets a dot.
> adding points?
> Chris Hermansen · clhermansen "at" gmail "dot" com
> C'est ma façon de parler.
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
Randal Hale
North Rivergeographic Systems, Inc
https://www.northrivergeographic.com
https://www.qgis-us.org
I hope this email finds you in the mountains, and as sun peeps through the trees the squirrels begin foraging.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20250326/335eabba/attachment-0001.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20250326/335eabba/attachment-0003.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20250326/335eabba/attachment-0004.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20250326/335eabba/attachment-0005.png>
More information about the QGIS-User mailing list
