[Qgis-user] 1. Best version for novice and 2. chained on-the-fly transformations
Emma Hain
emma at north-road.com
Mon May 12 15:40:36 PDT 2025
https://www.youtube.com/watch?v=7ost_OrTe30
Kind regards
Em
Emma Hain — Product Manager/Senior GIS Analyst
[image: https://north-road.com]
*North Road*
Cartography • Development • Spatial Analysis
*north-road.com* <http://north-road.com>
<https://twitter.com/northroadgeo>
<https://www.linkedin.com/company/north-road-studios>
<https://www.facebook.com/North-Road-997236690392419/home>
QGIS User Conference 2025 <https://uc2025.qgis.org/>
2-3 June, Norrköping, Sweden
FOSS4G 2025 <https://2025.foss4g.org/>
17-23 November, Auckland, New Zealand
On Tue, 13 May 2025 at 08:40, Emma Hain <emma at north-road.com> wrote:
> This video is helpful to take you through the steps - but does install
> the development version.
> Kind regards
> Em
> *North Road*
> On Fri, 9 May 2025 at 17:01, Tom Haws via QGIS-User <
> qgis-user at lists.osgeo.org> wrote:
>> Andrea,
>> Thank you very much for your kind help. Based on what you said, I
>> uninstalled and cleaned all traces of QGIS. Then I installed the 3.40.6
>> (Bratislava) LTS download (not installer). I was able to clip by mask layer
>> for the first time ever. It appeared to work, but I got an error message
>> that I will report in my other thread. I think I am back in the saddle now
>> with QGIS, thanks to you.
>> Tom
>> Tom Haws 480-201-5476 (founder of NPS <http://npsge.org/> 480-389-4583)
>> I am looking to join financial and intellectual forces with like minds
>> and hearts to buy (or build) and hold apartment complexes in perpetual
>> trusts. Let's talk.
>> I am transitioning away from this personal address (to
>> NPSGlobalinc at gmail.com) for engineering.
>> On Thu, May 8, 2025 at 4:48 PM Andrea Giudiceandrea via QGIS-User <
>>> > Tom Haws tom.haws at gmail.com
>>> > Thu May 8 12:47:53 PDT 2025
>>> > After installing OSGEO4W, I am having the following issues:
>>> > 1. There are six versions of QGIS in my Windows Start Menu, and I don't
>>> > know which one to run.
>>> Hi Tom,
>>> the installation guide says:
>>> Download OSGeo4W Installer and run it.
>>> Choose Express Install and select QGIS to install the latest release
>>> and/or QGIS LTR to install the long term release.
>>> Alternatively, instead of doing the Express install, you can use the
>>> Advanced Install, navigate to the Desktop section and pick one or more
>>> of the following packages:
>>> It's up to you to decide which version of QGIS to install. It looks like
>>> you have decided to install all the available QGIS versions.
>>> > 2. There is a new folder Desktop\OSGeo4W that has only shortcuts (over
>>> 30)
>>> > in it. I don't know if I can safely delete it.
>>> Not sure what do you mean with "safely".
>>> If the folder contains over 30 shortcuts, I guess you have installed
>>> every single package available through OSGeo4W. That is not recommanded
>>> and not needed.
>>> > 3. If I start 3.40.6,
>>> > a. the splash screen says it is "Long Term Release".
>>> This is correct.
>>> From the "Download" web page:
>>> "The long-term builds currently provide 3.40.6 'Bratislava'. Long Term
>>> Release (LTR) builds are intended for those who value stability over
>>> having the latest features. If you are unsure which version is best for
>>> you, download the LTR."
>>> > i. When I set the CRS to WGS84 (EPSG:4978) and try to add a raster
>>> > layer on EPGS:6341, I am getting this error message: "No transform is
>>> > available between NAD83(2011) / UTM zone 12N + NAVD88 height and
>>> EPSG:4978
>>> > - WGS 84.
>>> First of all, are you sure you actually need to use the Geocentric CRS
>>> EPSG:4978 WGS 84? Usually the Geographic CRS EPSG:4326 WGS 84 is used.
>>> Anyway, based on your other message, I guess the issue may be due to the
>>> fact that in your OSGeo4W installation, the PROJ library related
>>> packages are not up-to-date.
>>> Regards.
>>> Andrea
>>> QGIS-User mailing list
>>> QGIS-User at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20250513/06281e04/attachment.htm>
More information about the QGIS-User
