[Qgis-user] Support for 25.04 plucky penguin
Frank Sokolic
sokolic at worldonline.co.za
Sun May 18 01:58:19 PDT 2025
Hi Tony,
I had a similar problem on Kubuntu 25.04 and resolved it by installing
the Flatpak version of QGIS with this command: flatpak install flathub
org.qgis.qgis
This installs QGIS 3.42.2.
Frank.
On 2025/05/18 05:47, Tony Bazeley via QGIS-User wrote:
> I've just upgraded from oracular to 25.04 plucky penguin and now find
> 3.40.5-Bratislava is installed and I get an error on opening a project:
> "This project file was created by a newer version of QGIS
> (3.42.2-Münster) and could not be completely loaded."
> I can't see an entry for plucky in the repository
> <https://ubuntu.qgis.org/ubuntu/dists/?C=M;O=D>
> My /etc/apt/sources.list.d/qgis.sources is:Types: deb deb-src URIs:
> https://qgis.org/debian Suites: plucky Architectures: amd64
> Components: main Signed-By: /etc/apt/keyrings/qgis-archive-keyring.gpg
> Enabled: yes I've updated Suites to "plucky" and I suspect Enabled was
> updated to no on the upgrade.
> apt update yiels an error:
> Err:11 https://debian.qgis.org/debian plucky Release 404 Not Found
> [IP: 172.67.143.23 443] Error: The repository 'https://qgis.org/debian
> plucky Release' does not have a Release file. Notice: Updating from
> such a repository can't be done securely, and is therefore disabled by
> default.
> Any thoughts on the best way to proceed?
> Thanks
> Tony
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20250518/f3f2d540/attachment.htm>
More information about the QGIS-User
