[Qgis-user] Support for 25.04 plucky penguin
Tony Bazeley
tonyb at tonyb.id.au
Sun May 18 19:30:28 PDT 2025
Thanks Frank,
That's a good work around, but I think the core issue is the
unavailability of a Latest Release version for 25.04. I've created an
issue request <https://github.com/qgis/QGIS/issues/61898> as it's now
obvious more than one user is affected
Tony
On 18/5/25 18:28, Frank Sokolic via QGIS-User wrote:
> Hi Tony,
> I had a similar problem on Kubuntu 25.04 and resolved it by installing
> the Flatpak version of QGIS with this command: flatpak install flathub
> org.qgis.qgis
> This installs QGIS 3.42.2.
> Frank.
> On 2025/05/18 05:47, Tony Bazeley via QGIS-User wrote:
>> I've just upgraded from oracular to 25.04 plucky penguin and now find
>> 3.40.5-Bratislava is installed and I get an error on opening a project:
>> "This project file was created by a newer version of QGIS
>> (3.42.2-Münster) and could not be completely loaded."
>> I can't see an entry for plucky in the repository
>> <https://ubuntu.qgis.org/ubuntu/dists/?C=M;O=D>
>> My /etc/apt/sources.list.d/qgis.sources is:Types: deb deb-src URIs:
>> https://qgis.org/debian Suites: plucky Architectures: amd64
>> Components: main Signed-By:
>> /etc/apt/keyrings/qgis-archive-keyring.gpg Enabled: yes I've updated
>> Suites to "plucky" and I suspect Enabled was updated to no on the
>> upgrade.
>> apt update yiels an error:
>> Err:11 https://debian.qgis.org/debian plucky Release 404 Not Found
>> [IP: 172.67.143.23 443] Error: The repository
>> 'https://qgis.org/debian plucky Release' does not have a Release
>> file. Notice: Updating from such a repository can't be done securely,
>> and is therefore disabled by default.
>> Any thoughts on the best way to proceed?
>> Thanks
>> Tony
>> QGIS-User mailing list
>> QGIS-User at lists.osgeo.org
>> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20250519/7a2ca8dc/attachment.htm>
More information about the QGIS-User
