[Qgis-user] Model designer: Using value from a Number input as a parameter in a Raster Calculator expression
Bo Victor Thomsen
bo.victor.thomsen at gmail.com
Tue May 27 02:02:14 PDT 2025
Hi list -
I can't find a method to use a Number input as a part of raster
calculator expression in Model Designer.
Using QGIS version 3.42, in Model Designer I've:
* Defined a Number Input field: /my_number/
* Defined a Raster Layer selector : /my_raster/
* Defined a Rater Calculator algorithm: /multiplication/
Now the crucial question: How to use the number from my number input in
an expression inside Raster Calculator?
Ex. for a simple multiplication: /"A at 1" * parameter('my_number')/ or
/"A at 1" * @my_number/
Whatever I do, I get an error message like this:
Algorithm 'model' starting…
Input parameters:
{ 'my_number' : 22, 'my_raster' :
'D:/gis/gis_analyser/flis_volumen/normaliseret.tif', 'resultat' :
'TEMPORARY_OUTPUT' }
Prepare algorithm: native:modelerrastercalc_1
Running multiplication [1/1]
Input Parameters:
{ CELL_SIZE: None, CREATION_OPTIONS: None, CRS: None, EXPRESSION: '"A at 1"
* parameter(\'my_number\')', EXTENT: None, LAYERS:
['D:/gis/gis_analyser/flis_volumen/normaliseret.tif'], OUTPUT:
Error encountered while running multiplication: Error parsing formula.
Execution failed after 0.04 seconds
The error message indicate an error in my expression: /"A at 1" *
So, how do i declare and use a Number Input inside a raster calculator
expression ??
Med venlig hilsen / Best regards
Bo Victor Thomsen
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20250527/7af9b766/attachment.htm>
More information about the QGIS-User
