[Qgis-user] Model designer: Using value from a Number input as a parameter in a Raster Calculator expression
Martin Weis
martin.weis.newsadress at gmx.de
Wed May 28 11:05:00 PDT 2025
Hello,
Try pre-calculated formula:
'A* ' || @number
see the model in this gist:
https://gist.github.com/Marwe/32c41f69e99782b023c34b913b507470
Worked for me :)
Have fun
Martin
Am 27.05.25 um 11:02 schrieb Bo Victor Thomsen via QGIS-User:
> Hi list -
> I can't find a method to use a Number input as a part of raster
> calculator expression in Model Designer.
> Using QGIS version 3.42, in Model Designer I've:
> * Defined a Number Input field: /my_number/
> * Defined a Raster Layer selector : /my_raster/
> * Defined a Rater Calculator algorithm: /multiplication/
> Now the crucial question: How to use the number from my number input in
> an expression inside Raster Calculator?
> Ex. for a simple multiplication: /"A at 1" * parameter('my_number')/
> or /"A at 1" * @my_number/
> Whatever I do, I get an error message like this:
> Algorithm 'model' starting…
> Input parameters:
> { 'my_number' : 22, 'my_raster' : 'D:/gis/gis_analyser/flis_volumen/
> normaliseret.tif', 'resultat' : 'TEMPORARY_OUTPUT' }
> Prepare algorithm: native:modelerrastercalc_1
> Running multiplication [1/1]
> Input Parameters:
> { CELL_SIZE: None, CREATION_OPTIONS: None, CRS: None, EXPRESSION: '"A at 1"
> * parameter(\'my_number\')', EXTENT: None, LAYERS: ['D:/gis/
> gis_analyser/flis_volumen/normaliseret.tif'], OUTPUT: 'TEMPORARY_OUTPUT' }
> Error encountered while running multiplication: Error parsing formula.
> Execution failed after 0.04 seconds
> The error message indicate an error in my expression: /"A at 1" *
> So, how do i declare and use a Number Input inside a raster calculator
> expression ??
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
More information about the QGIS-User
