[Qgis-user] Model designer: Using value from a Number input as a parameter in a Raster Calculator expression
Bo Victor Thomsen bo.victor.thomsen at gmail.com
Fri May 30 07:05:46 PDT 2025
Thanks Martin,  for the heads-up.
In hindsight, the Model Designer of course needs a "pre-calculate"
feature like this to incorporate external programs and function
libraries ( that is not capable of directly read and evaluate a QGIS
internal variable or expression).
Med venlig hilsen / Best regards
Bo Victor Thomsen
On 28/05/2025 20.05, Martin Weis via QGIS-User wrote:
> Hello,
> Try pre-calculated formula:
> 'A* ' || @number
> see the model in this gist:
> https://gist.github.com/Marwe/32c41f69e99782b023c34b913b507470
> Worked for me :)
> Have fun
> Martin
> Am 27.05.25 um 11:02 schrieb Bo Victor Thomsen via QGIS-User:
>> Hi list -
>> I can't find a method to use a Number input as a part of raster
>> calculator expression in Model Designer.
>> Using QGIS version 3.42, in Model Designer I've:
>>   * Defined a Number Input field: /my_number/
>>   * Defined a Raster Layer selector : /my_raster/
>>   * Defined a Rater Calculator algorithm: /multiplication/
>> Now the crucial question: How to use the number from my number input
>> in an expression inside Raster Calculator?
>> Ex. for a simple multiplication: /"A at 1" * parameter('my_number')/ or
>> /"A at 1" * @my_number/
>> Whatever I do, I get an error message like this:
>> Algorithm 'model' starting…
>> Input parameters:
>> { 'my_number' : 22, 'my_raster' : 'D:/gis/gis_analyser/flis_volumen/
>> normaliseret.tif', 'resultat' : 'TEMPORARY_OUTPUT' }
>> Prepare algorithm: native:modelerrastercalc_1
>> Running multiplication [1/1]
>> Input Parameters:
>> { CELL_SIZE: None, CREATION_OPTIONS: None, CRS: None, EXPRESSION:
>> '"A at 1" * parameter(\'my_number\')', EXTENT: None, LAYERS: ['D:/gis/
>> gis_analyser/flis_volumen/normaliseret.tif'], OUTPUT:
>> Error encountered while running multiplication: Error parsing formula.
>> Execution failed after 0.04 seconds
>> The error message indicate an error in my expression: /"A at 1" *
>> So, how do i declare and use a Number Input inside a raster
>> calculator expression ??
>> QGIS-User mailing list
>> QGIS-User at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
More information about the QGIS-User mailing list
