[Qgis-user] Qgis Form // Attached tool / Big performance problem for table opening
Tobias Schula
geospatial at schula.org
Wed Oct 8 05:09:48 PDT 2025
Am 05.10.25 um 20:18 schrieb celati Laurent via QGIS-User:
> I work with Windows with Qgis 3.34.13-Prizren.
> I have a Qgis project destined to be shipped on a tablet for the field
> (Qfield).
> The project contains a polygonal layer of 3427 objects (file shp). There
> are many columns with different types. There also relational values /
joins
> setted for this form. So the project also includes .csv files (for
> relational values).
Have you tried putting all the data into a database? For example a
single geopackage file? Reading CSV is slower than from SQLite.
Geopackage is an SQLite database.
> The problem : the opening of this table attribute takes up to 40
seconds. I
> spent time to identify where the problem may come from. At one time I
> thought for joins/relational values. Or also CSV format. As we can
see here
https://gis.stackexchange.com/questions/423054/what-is-slowing-qgis-the-most-when-opening-form
> After several hours of investigation, the source of the problem seems to
> come from 4 columns (string) for strore the pictures. After removing
those
> 4 columns of the form, the opening time of the table become normal.
> I have tried to "play" with the parameter for this form attached
tool, (as
> for example relative/absolute path size of the images, etc.). But in
vain.
Are you storing the picture in a separate table? For pictures, this is
the approach QField recommends: https://docs.qfield.org/how-to/pictures/
Tobias A Schula
Forestry Expert
Type: application/pgp-keys
Desc: OpenPGP public key
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20251008/e5360a09/attachment.key>
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20251008/e5360a09/attachment.sig>
More information about the QGIS-User
