[Qgis-user] Export problem with layout
Vedran Stojnović
phidrho at gmail.com
Sat Oct 11 04:14:49 PDT 2025
I had similar problem few months ago, and I believe it was related to
creating project in newer version of QGIS (3.42) and then continuing working
in older version (3.40).
My solution was to create entire project from scratch in lower version and
then it was everything OK. I think that even if you open project once in
newer version and save it without making any chages it could mess things up
with printing/exporting from layout.
čet, 9. lis 2025. u 23:57 Phil Wyatt via QGIS-User <
qgis-user at lists.osgeo.org> napisao je:
> Hi Mattie,
> Give us some clues as to what layers are in the layout? Network layers,
> raster, vectors, same user logins, same network?
> Cheers - Phil,
> On 9 Oct 2025, at 7:09 pm, metti play via QGIS-User <
> qgis-user at lists.osgeo.org> wrote:
> Good morning everyone,
> I am experiencing a problem with QGIS on several laptops with different
> processors and video cards.
> When exporting with Layout, it loads indefinitely and crashes.
> I don't understand what the problem is, unfortunately QGIS does not leave
> me any logs to better understand the problem.
> Has this ever happened to you? The laptops had the following
> configurations:
> - Laptop 1: i9-14th, 32 GB RAM, RTX 3500
> - Laptop 2: Ultra 7, 32 GB RAM, RTX A500
> - Laptop 3: AMD Ryzen 5 220 w/ Radeon 740M Graphics, 16GB RAM
> - Laptop 4: i7-11th, 16 GB RAM
> While it works on my PC, which has an i5-11th and 16 GB RAM, all tests
> were performed with QGIS 3.40.11 LTR using the same project.
> Can you give us some tips to solve the problem?
> Best regards,
> Mattia
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
Srdačan pozdrav / Kind regards,
Vedran Stojnović.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20251011/66b696cb/attachment.htm>
More information about the QGIS-User
