[Qgis-user] Export problem with layout
metti play
mettimat116 at gmail.com
Sat Oct 11 06:35:58 PDT 2025
thank you very much for your reply. One thing I have noticed is that in the
project there are layers taken from the Internet by the Swiss Federation.
if I export with the pc disconnected from the internet, it works. But
obviously the layers that it should recover from the internet are missing.
Has it ever happened to you? among other things, I am doing the tests
connected to a network cable with a very fast business connection if I am
not mistaken it goes to 10 Gb/s.
Thanks a lot and have a good continuation
Matthew
Il Sab 11 Ott 2025, 13:15 Vedran Stojnović <phidrho at gmail.com> ha scritto:
> Hi,
> I had similar problem few months ago, and I believe it was related to
> creating project in newer version of QGIS (3.42) and then continuing working
> in older version (3.40).
> My solution was to create entire project from scratch in lower version and
> then it was everything OK. I think that even if you open project once in
> newer version and save it without making any chages it could mess things up
> with printing/exporting from layout.
> čet, 9. lis 2025. u 23:57 Phil Wyatt via QGIS-User <
> qgis-user at lists.osgeo.org> napisao je:
>> Hi Mattie,
>> Give us some clues as to what layers are in the layout? Network layers,
>> raster, vectors, same user logins, same network?
>> Cheers - Phil,
>> On 9 Oct 2025, at 7:09 pm, metti play via QGIS-User <
>> qgis-user at lists.osgeo.org> wrote:
>> Good morning everyone,
>> I am experiencing a problem with QGIS on several laptops with different
>> processors and video cards.
>> When exporting with Layout, it loads indefinitely and crashes.
>> I don't understand what the problem is, unfortunately QGIS does not leave
>> me any logs to better understand the problem.
>> Has this ever happened to you? The laptops had the following
>> configurations:
>> - Laptop 1: i9-14th, 32 GB RAM, RTX 3500
>> - Laptop 2: Ultra 7, 32 GB RAM, RTX A500
>> - Laptop 3: AMD Ryzen 5 220 w/ Radeon 740M Graphics, 16GB RAM
>> - Laptop 4: i7-11th, 16 GB RAM
>> While it works on my PC, which has an i5-11th and 16 GB RAM, all tests
>> were performed with QGIS 3.40.11 LTR using the same project.
>> Can you give us some tips to solve the problem?
>> Best regards,
>> Mattia
>> QGIS-User mailing list
>> QGIS-User at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> Srdačan pozdrav / Kind regards,
> Vedran Stojnović.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20251011/642c7fcc/attachment.htm>
More information about the QGIS-User
