[Qgis-user] Saving to Geopackage does not contain CRS
Richard Duivenvoorde
rdmailings at duif.net
Fri Oct 17 03:33:41 PDT 2025
Hi Jeroen,
I cannot reproduce your issue here: if I have a layer with proper defined crs (!), and I export it to gpkg then after loading the gpkg layer has the right crs too.
Note that if the original one does not have a crs defined (via layer props or context menu), then QGIS uses 10000 as default (user) value.
So main question: has the data from which you export/save to gpkg the right crs?
Are you using a recent QGIS version? On which platform?
Can you maybe provide a small sample gpkg on which this issue occurs?
Regards,
On 17-10-2025 12:21, Jeroen de Jong - Periplus Group via QGIS-User wrote:
> Hello,
> When I save my data to Geopackage the CRS information is not included in the Geopackage correctly. Instead the default value 100000 is being stored.
> Does anyone have an idea how to fix this?
> Kind regards / Met vriendelijke groet,
> Jeroen de Jong
> Hydrographic Consultant
> ____________________________________________________________________________________________ _
> Group-RGB-email-signature
> Kraanspoor 22
> 1033 SE Amsterdam
> The Netherlands
> t: +31206367891
> _j.d.jong at periplus.nl <mailto:j.d.jong at periplus.nl>_
> _www.periplus.nl <http://www.periplus.nl/>_
> Part of Periplus Holding BV (CC37114418)
> We are ISO:9001 and OHSAS:18001 certified.
> Pplease don’t print this email unless you really need to
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
More information about the QGIS-User
