[Qgis-user] Raster Attribute Table
    Marc Bordelon
    marcbordelon at yahoo.com
    Fri Oct 17 13:50:12 PDT 2025
I've been using QGIS for about 4 years now. I'm presently running 3.40.10. I've created a DEM raster layer with 15 classes based on 0.5ft contours. I've also created the symbology to reflect these classes, along with an attribute table. The table looks great but I can't edit the table to remove all the columns (with band colors). All I need is the contour breaks along with the colors.
Is there a way to remove these columns. I can edit the table, but only to add a column not to remove a column.
If I convert the DEM Raster layer to a Vector layer only 2 columns are converted (id, elevation) none of the others are converted.
Is there a fix for this or is there another way to get an attribute table to reflect elevation contours along with colors.
Any help would be greatly appreciated.
Marc J. BordelonSoil Scientist
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20251017/67c4a546/attachment.htm>
More information about the QGIS-User
