[Qgis-user] Scale
Aron Gergely
aron.gergely at rasterra.nl
Fri Oct 17 02:29:41 PDT 2025
[in Hungarian]
Szia Lajos!
Udv a nemzetkozi QGIS taborban!
A tanacsom, hogy inkabb a QGIS-ben bizz, mint az AI-ban. :) Legy az
utobbi fele nagyon kritikus, plane ha szamodra uj dologba fogsz.
Szoval, ha QGIS 1:10000-es meretaranyt mutat, az mervado, mint azt a
matekod is igazolja.
A terkepedre be is tudsz illeszteni egy ilyen grafikai elemet ami a
merataranyt feltunteti.
Ha az angol nyelv gondot okoz, akkor keresd fel a magyar informalis QGIS
felhasznaloi kozosseget,
azt hiszem van egy a LinkedIn-en.
Illetve felkeresheted Siki Zoltant a BME professzorat, o a Magyar
korokben a QGIS huzoereje, valamint remek figura.
Sok sikert!
[in English]
Hi Lajos,
Welcome to the international QGIS camp!
My advice: rather trust QGIS than AI. Be very critical about the latter,
especially when undertaking something new to you.
If QGIS reports the scale to be 1:10000 then it's probably right, as
your math also confirms.
You can in fact insert such a graphical element on your map layout which
shows the scale on the map.
If English gives you trouble, you can look for the informal Hungarian
user communities, I believe they are mostly in LinkedIn / FB groups..
You can also find Zoltan Siki, a professor at BME who is the driving
force behind local QGIS / FOSS communities. Also a great guy.
Good luck!
On 10/16/25 16:03, Lajos Tolnai via QGIS-User wrote:
> Hello!
> I will try to write short sentences so that the translation remains
> understandable.
> I am a QGIS user by chance.
> I started using it because AI encouraged me to.
> I needed a map.
> AI helped me, and now I'm done.
> But something is bothering me.
> In the print window, the Scala value is 7500.
> The AI claims that this is the scale.
> But that can't be right.
> A section 14 km wide and 23 km high is displayed.
> On a surface 1.4 m wide and 2 m high.
> What I would like to know is: Does the scale value really correspond
> to the 1:10,000 scale shown on the maps?
> Thanks in advance for your replies.
> Lajos
> Sziasztok!
> Megpróbálok rövid mondatokat írni, hogy a fordítás érthető maradjon.
> Véletlenül vagyok QGIS felhasználó.
> Az AI biztatására kezdtem bele.
> Szükségem volt egy térképre.
> Az AI segített, kész vagyok.
> De valami nagyon zavar.
> A nyomtatási ablakban a Scala érték 7500.
> Az AI állítja, hogy az a méretarány.
> De az nem lehet.
> Egy 14 km széles és 23 km magas szelvény van kiterítve.
> 1,4 m széles és 2 m magas felületre.
> Amit szeretnék megtudni: A scála érték valóban megegyezik a térképeken
> látható 1:10.000 aránnyal?
> Köszönöm előre is a válaszokat.
> Lajos
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
Email Signature Kind Regards,
Aron Gergely
+31 (0) 6 38 70 97 66
*Rasterra* | www.rasterra.nl <https://www.rasterra.nl>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20251017/7c0c7e7f/attachment.htm>
More information about the QGIS-User
