[Qgis-user] again QGIS won't open
Andrea Giudiceandrea andreaerdna at libero.it
Sun Sep 7 17:47:35 PDT 2025
Il 08/09/2025 00:01, Stephen Sacks ha scritto:
>    Here's what I did:
> 1.   Windows key + R   gets me to a Run window and then CMD gets me to a
> command prompt.
>   2.  chdir c:\osgeo4w  gets me to the OSGeo4W folder.
Hi Stephen,
in a previous message, Jürgen E. Fischer advised you to
 > Try a fresh profile by starting QGIS from the OSGeo4W shell:
 > qgis-ltr --profile my-new-profile
You replayed that such advise fixed the issue.
Since the issue is the same, the advise is the same. You need to use a
new profile, different from "my-new-profile". For example:
"my-new-profile2".
So...
Try again to use a fresh profile by starting QGIS from the OSGeo4W Shell
(you need to use the OSGeo4W Shell, not the normal Command Prompt):
qgis-ltr --profile my-new-profile2
Regards.
Andrea
More information about the QGIS-User mailing list
