[Qgis-user] python scripts in the console have stopped working
Don Harter
harterc2 at att.net
Fri Sep 19 22:39:29 PDT 2025
Part of my problems seem to have been from a corrupted config file. I
deleted all the layers in each group and reloaded them. I was seeing
qgis crash.
I also reinstalled my amd graphics drivers.
Things seem to be working again for 1:3.40.11+17bookworm amd64 version.
I could not build it from the source because a find cmake file was not
finding the debian libraries.
"CMake Error at cmake/FindQCA.cmake:64 (message):
Could not find QCA"
On 9/18/25 8:47 AM, Don Harter via QGIS-User wrote:
> I have a good idea on what has happened. I tried to build qgis from
> the latest source like I have done before.
> I saw a message about qt5 should not be used since it gives unstable
> results. I use basically debian bookworm LMDE.
> That distribution does not have qt6 with the needed minimum version.
> So I would have to upgrade to the experimental version of debian or
> the latest one that just came out. Using regression I have had varied
> success running some of my scripts. Any binaries built by a developer
> must have been built on those versions of distributions. Perhaps some
> binaries could be built which using non-shared libraries.
> On 9/17/25 7:58 AM, Don Harter via QGIS-User wrote:
>> REcently I upgradded a couple of times to. Now it seems that the
>> scripts that I use in the console to load raster and vector files
>> into groups no longer work.
>> I can see in the console that the execute command gets run, but that
>> is all that it does.
>> Any ideas on what might have happened?
>> ii python3 3.11.2-1+b1 amd64
>> ii qgis 1:3.44.1+17bookworm amd64
>> Here is an image of what happens.
>> QGIS version
>> 3.44.1-Solothurn
>> QGIS code revision
>> c8b94a2061d
>> Libraries
>> Qt version
>> 5.15.8
>> Python version
>> 3.11.2
>> GDAL version
>> 3.6.2
>> PROJ version
>> 9.1.1
>> EPSG Registry database version
>> v10.076 (2022-08-31)
>> GEOS version
>> 3.11.1-CAPI-1.17.1
>> SQLite version
>> 3.40.1
>> PostgreSQL client version
>> 15.13
>> SpatiaLite version
>> 5.0.1
>> QWT version
>> 6.1.4
>> QScintilla2 version
>> 2.13.3
>> OS version
>> LMDE 6 (faye)
>> Active Python plugins
>> qfieldsync
>> v4.17.3
>> LAStools
>> 2.3.2
>> qgsAzimuth
>> 0.9.19
>> Serval
>> 3.32.0
>> rvt-qgis
>> 0.9.6
>> OSMDownloader
>> 1.0.3
>> poiexport
>> 3.0.5
>> pdaltools
>> 0.1.6
>> geol_qmaps
>> 3.1.4
>> AzimuthMeasurement
>> 0.2.2
>> wbt_for_qgis
>> 1.0.9
>> AzimuthDistanceCalculator
>> 2.0.2
>> osminfo
>> 1.2.1
>> locationiq-qgis
>> 3.0.6
>> leastcostpath
>> 1.1
>> open_lidar_tools
>> 2.3
>> processing_saga_nextgen
>> 1.1.0
>> DigitizingTools
>> 1.5.3
>> openlayers_plugin
>> 2.0.0
>> pobieracz_danych_gugik
>> 1.2.10
>> QGIS-User mailing list
>> QGIS-User at lists.osgeo.org
>> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20250920/369844f1/attachment-0001.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20250920/369844f1/attachment-0001.png>
More information about the QGIS-User
