[Qgis-user] python scripts in the console have stopped working
Don Harter
harterc2 at att.net
Thu Sep 18 05:47:25 PDT 2025
I have a good idea on what has happened. I tried to build qgis from the
latest source like I have done before.
I saw a message about qt5 should not be used since it gives unstable
results. I use basically debian bookworm LMDE.
That distribution does not have qt6 with the needed minimum version. So
I would have to upgrade to the experimental version of debian or the
latest one that just came out. Using regression I have had varied
success running some of my scripts. Any binaries built by a developer
must have been built on those versions of distributions. Perhaps some
binaries could be built which using non-shared libraries.
On 9/17/25 7:58 AM, Don Harter via QGIS-User wrote:
> REcently I upgradded a couple of times to. Now it seems that the
> scripts that I use in the console to load raster and vector files into
> groups no longer work.
> I can see in the console that the execute command gets run, but that
> is all that it does.
> Any ideas on what might have happened?
> ii python3 3.11.2-1+b1 amd64
> ii qgis 1:3.44.1+17bookworm amd64
> Here is an image of what happens.
> QGIS version
> 3.44.1-Solothurn
> QGIS code revision
> c8b94a2061d
> Libraries
> Qt version
> 5.15.8
> Python version
> 3.11.2
> GDAL version
> 3.6.2
> PROJ version
> 9.1.1
> EPSG Registry database version
> v10.076 (2022-08-31)
> GEOS version
> 3.11.1-CAPI-1.17.1
> SQLite version
> 3.40.1
> PostgreSQL client version
> 15.13
> SpatiaLite version
> 5.0.1
> QWT version
> 6.1.4
> QScintilla2 version
> 2.13.3
> OS version
> LMDE 6 (faye)
> Active Python plugins
> qfieldsync
> v4.17.3
> LAStools
> 2.3.2
> qgsAzimuth
> 0.9.19
> Serval
> 3.32.0
> rvt-qgis
> 0.9.6
> OSMDownloader
> 1.0.3
> poiexport
> 3.0.5
> pdaltools
> 0.1.6
> geol_qmaps
> 3.1.4
> AzimuthMeasurement
> 0.2.2
> wbt_for_qgis
> 1.0.9
> AzimuthDistanceCalculator
> 2.0.2
> osminfo
> 1.2.1
> locationiq-qgis
> 3.0.6
> leastcostpath
> 1.1
> open_lidar_tools
> 2.3
> processing_saga_nextgen
> 1.1.0
> DigitizingTools
> 1.5.3
> openlayers_plugin
> 2.0.0
> pobieracz_danych_gugik
> 1.2.10
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20250918/63fd7e77/attachment.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20250918/63fd7e77/attachment.png>
More information about the QGIS-User
