[Qgis-user] again QGIS won't open
Tobias Schula geospatial at schula.org
Wed Sep 10 07:03:30 PDT 2025
Am 08.09.25 um 00:01 schrieb Stephen Sacks via QGIS-User:
>    Here's what I did:
> 1.   Windows key + R   gets me to a Run window and then CMD gets me to a
> command prompt.
>   2.  chdir c:\osgeo4w  gets me to the OSGeo4W folder.
>   3.  Separately, I tried each of the following four commands:
>        c.  qgis
>        b.  qgis --profile my-new-profile
>        c.  qgis-ltr --profile my-new-profile
>        d.  qgis --noplugins
> In each case the response is:  'qgis'  is not recognized as an internal
> or external command, operable program or batch file.
Don't open a regular command prompt! You need to explicitly open the
OSGeo4W shell. This shell will set the needed environment variables to
be able to successfully launch QGIS. You'll find the OSGeo4W shell
either in the start menu and/or on the desktop in the OSGeo4W folder.
> Shall I re-install QGIS 3.40 ?Since you've mentioned that you've changed some Python scripts, yes.
Backup your profile from:
 > C:\Users\<your_user_name>\AppData\Roaming\QGIS\QGIS3\profiles ,
uninstall everything, after uninstalling remove the C:\OSGeo4W folder,
download the most recent installer and reinstall. If you need to run
QGIS or other OSGeo4W software from the command line, always use the
OSGeo4W shell!
Best regards
Tobias A Schula
Forestry Expert
Type: application/pgp-keys
Desc: OpenPGP public key
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20250910/7e9ee2d9/attachment.key>
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20250910/7e9ee2d9/attachment.sig>
More information about the QGIS-User mailing list
