[Qgis-user] Presque Isle State Park Map (Erie, PA)
Greg Troxel
gdt at lexort.com
Fri Apr 3 08:00:49 PDT 2026
James Kolakowski via QGIS-User <qgis-user at lists.osgeo.org> writes:
> I am currently using QGIS to make a map of Presque Isle State Park in Erie,
> PA, but need help with making a map (North Arrow, Scale Bar, Legend, etc).
Are you doing this as an indivdual hobbyist, as your use of gmail
suggests, or are you part of park management, or ? (OK to ask for help
either way, but I think organizational use asking for help should use
organizational emails.)
> I tried experimenting with QGIS to solve the issue myself and used Internet
> AI tutorials to solve the issue, but none of those methods worked. Any
> help I receive would be greatly appreciated.
I am shocked, shocked that "AI tutorials" were not useful. Most
egregiously, they seem not to have made you aware of the actual
documentation. I suggest that you and everybody else not encourage
"AI" and all its problems by looking at them.
Some actual human-written correct content to read:
https://docs.qgis.org/3.44/en/docs/user_manual/index.html
and specifically:
https://docs.qgis.org/3.44/en/docs/user_manual/print_layout/index.html
What you are trying to do is not odd, so it should be straightforward.
I recommend that you have a project where you only have layers that you
want in the map. That should ease the process of displaying the Legend.
I forget the customization details, but pretty much everything I used to
know was in the manual.
More information about the QGIS-User
