[Qgis-user] How to download QGIS 4.0.1 on macOS?
nwastra nwastra
nwastra at gmail.com
Sun Apr 12 01:36:25 PDT 2026
Hi Thomas, I was having trouble getting $.0 to open on my imac.
I downloaded the latest “master from here and it gave my 4.0.1 and it works fine now.
https://github.com/qgis/QGIS/actions/workflows/build-macos-qt6.yml
Select the link next to the green tick and then scroll to bottom and there is a dmg to download.
You will need to control click to open it on the mac.
Nev
> On 12 Apr 2026, at 5:29 pm, Thomas Wölk via QGIS-User <qgis-user at lists.osgeo.org> wrote:
> Hi list,
> I'm trying to download QGIS 4.0.1 on macOS. The link on the QGIS welcome screen points to the download page, but whatever I download there turns out to be 4.0.0 - even though 4.0.1 has already been released.
> To make matters worse, the filenames of the installer packages don't include the version number, so there's no way to tell from the filename alone which release you're actually getting.
> Two questions:
> 1. Where can I reliably download the 4.0.1 package for macOS?
> 2. Has the version discrepancy on the download page been noticed, or is there a known workaround (e.g. a direct link or a specific mirror)?
> As a side note: it might be worth reconsidering the file naming convention for macOS packages so that the version number is reflected in the filename. That would make it a lot easier to verify what you've downloaded without having to open the application first.
> TIA,
> Thomas
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20260412/4f2fe9d6/attachment.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20260412/4f2fe9d6/attachment.png>
More information about the QGIS-User
