[Qgis-user] QGIS 4.0 - split selected multipart feature
Alexandre Neto senhor.neto at gmail.com
Tue Apr 21 07:51:44 PDT 2026
Hi Simon,
I am the author of the Multipart split plugin. I will see if I can find
time to update it to work with version 4.0. Meanwhile, what Andrea
suggested is a good workaround.
Alex
On Tue, 21 Apr 2026 at 12:45, Andrea Giudiceandrea via QGIS-User <
qgis-user at lists.osgeo.org> wrote:
> > Simon Dietmann dietmann at pgnu.de
> > Tue Apr 21 01:09:13 PDT 2026
> > after doing some research I found that the multipart split plugin is not
> compatible with QGIS 4.0 and that there is afaics no equivalent
> functionality. Does anyone know any efficient workaround for this?
> Hi Simon,
> you could use the native "Multipart to singleparts" processing algorithm
> in the "Edit Features In-place" mode.
> You just need to:
> - make the layer editable
> - select the feature you want to process
> - activate the "Edit Features In-place" mode in the processig toolbox
> - execute the "Multipart to singleparts" processing algorithm
> Regards.
> Andrea
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20260421/6788f4f8/attachment.htm>
More information about the QGIS-User mailing list
