[Qgis-user] QGIS 4.0 - split selected multipart feature
Alexandre Neto
senhor.neto at gmail.com
Thu Apr 23 03:10:03 PDT 2026
Hello Simon,
I am happy to announce that I have updated the multipart split plugin to be
compatible with QGIS 4.0.
Hope it's useful!
Alex
On Tue, 21 Apr 2026 at 15:51, Alexandre Neto <senhor.neto at gmail.com> wrote:
> Hi Simon,
> I am the author of the Multipart split plugin. I will see if I can find
> time to update it to work with version 4.0. Meanwhile, what Andrea
> suggested is a good workaround.
> Alex
> On Tue, 21 Apr 2026 at 12:45, Andrea Giudiceandrea via QGIS-User <
> qgis-user at lists.osgeo.org> wrote:
>> > Simon Dietmann dietmann at pgnu.de
>> > Tue Apr 21 01:09:13 PDT 2026
>> > after doing some research I found that the multipart split plugin is
>> not compatible with QGIS 4.0 and that there is afaics no equivalent
>> functionality. Does anyone know any efficient workaround for this?
>> Hi Simon,
>> you could use the native "Multipart to singleparts" processing algorithm
>> in the "Edit Features In-place" mode.
>> You just need to:
>> - make the layer editable
>> - select the feature you want to process
>> - activate the "Edit Features In-place" mode in the processig toolbox
>> - execute the "Multipart to singleparts" processing algorithm
>> Regards.
>> Andrea
>> QGIS-User mailing list
>> QGIS-User at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20260423/b87f4005/attachment-0001.htm>
More information about the QGIS-User
