[Qgis-user] Integrate custom transformation to Proj Database for use in QGIS
Andrea Giudiceandrea
andreaerdna at libero.it
Tue Apr 28 07:54:10 PDT 2026
Hi Klaus,
AFAIK the officially supported method to use a custom NTv2 grid shift
file is described in the QGIS Desktop User Guide / Manual at
https://docs.qgis.org/3.44/en/docs/user_manual/working_with_projections/working_with_projections.html#integrate-an-ntv2-transformation-in-qgis
Modifying the PROJ database proj.db is not officially supported. The
structure of such database and the tables that needs to be modified may
differs from version to version, thus the exact way to modify it depends
on the PROJ version.
What is the PROJ version used by QGIS in your system?
How do you exactly modified proj.db?
Regards.
Andrea
More information about the QGIS-User
