[Qgis-user] Integrate custom transformation to Proj Database for use in QGIS
Klaus Mithöfer
mithoefer at gbd-consult.de
Tue Apr 28 09:43:56 PDT 2026
Hi Andrea
i use proj 9.4.0. I want to add a transformation similar to an existing
one (code 15984 EPSG 32467 to 258322). But I want to use a different
Transformation grid.
Proj.db has a table grid_transformation. I have added a data set similar
to 15984 to code 15984 but with a different grid name. the Grid is
stored in the proj folder. But the transformation did not show up when
addig the data - only the existing ones.
Kind regards
Klaus
Am 28.04.26 um 16:54 schrieb Andrea Giudiceandrea via QGIS-User:
> Hi Klaus,
> AFAIK the officially supported method to use a custom NTv2 grid shift
> file is described in the QGIS Desktop User Guide / Manual at https://
> docs.qgis.org/3.44/en/docs/user_manual/working_with_projections/
> working_with_projections.html#integrate-an-ntv2-transformation-in-qgis
> Modifying the PROJ database proj.db is not officially supported. The
> structure of such database and the tables that needs to be modified may
> differs from version to version, thus the exact way to modify it depends
> on the PROJ version.
> What is the PROJ version used by QGIS in your system?
> How do you exactly modified proj.db?
> Regards.
> Andrea
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
More information about the QGIS-User
