[Qgis-user] Integrate custom transformation to Proj Database for use in QGIS
Andrea Giudiceandrea
andreaerdna at libero.it
Tue Apr 28 15:23:49 PDT 2026
> Klaus Mithöfer mithoefer at gbd-consult.de
> Tue Apr 28 09:43:56 PDT 2026
> i use proj 9.4.0. I want to add a transformation similar to an existing
> one (code 15984 EPSG 32467 to 258322). But I want to use a different
> Transformation grid.
> Proj.db has a table grid_transformation. I have added a data set similar
> to 15984 to code 15984 but with a different grid name.
You probably meant "code 15948 EPSG 31467 to 25832".
For PROJ 9.4, you also need to modify the "usage" table, other then the
"grid_transformation" table, adding a row corresponding with the row
added in the "grid_transformation" table.
For example, the following SQL statements add the needed rows for a NTv2
transformation similar to EPSG:15948 but using the BETA2007_CUSTOM.gsb
grid shift file:
INSERT INTO "grid_transformation"
VALUES ('PROJ', 'DHDN_TO_ETRS89_CUSTOM', 'DHDN to ETRS89 (CUSTOM)',
NULL, 'EPSG', '9615', 'NTv2', 'EPSG', '4314', 'EPSG', '4258', '0.9',
'EPSG', '8656', 'Latitude and longitude difference file',
'BETA2007_CUSTOM.gsb', NULL, NULL, NULL, NULL, NULL, NULL, NULL, '0');
INSERT INTO "usage"
VALUES (NULL, NULL, 'grid_transformation', 'PROJ',
'DHDN_TO_ETRS89_CUSTOM', 'EPSG', '3339', 'EPSG', '1041');
Regards.
Andrea
More information about the QGIS-User
