[Qgis-user] QGIS Plugins Blocked - Reg
Greg Troxel gdt at lexort.com
Mon Aug 3 03:25:31 PDT 2026
"Srirangan, Baskar via QGIS-User" <qgis-user at lists.osgeo.org> writes:
> Hi Team,
This is the mailing list for users.   I'm not sure what "Team" is meant
to say.
> In our Environment we are using a security tool knows as zscalar to
> block unwanted contents , this tool has blocked all the plugin for
> QGIS, the reason is the plugin shows as zip and getting blocked
If you want to block zip files, that is your decision.  It seems clear
that you are using a tool that isn't doing what you want.  I believe
that you should seek support from your security tool vendor, or make
different choices about security tools.
> Our team would like to know if the zip contains any exe or any
> suspicious file or connection that need to be allowed in order for the
> plugins to work
I don't understand why you are asking this question.   Surely you would
have unpacked the extension zip and examined it.   What did you find?
More information about the QGIS-User mailing list
