[Qgis-user] when I try to look at the properties of a layer which did not load, qgis crashes
Don Harter
harterc2 at att.net
Tue Aug 4 17:31:47 PDT 2026
QGIS version
4.2.1-Belém do Pará
qgis 2026-08-04 20:29:30,471 - QuickOSM - INFO - Plugin loaded with
version : 2.5.3 proj_create: Error 1029 (File not found or invalid):
pipeline: Pipeline: Bad step definition: inv (File not found or invalid)
proj_create: Error 1029 (File not found or invalid): pipeline: Pipeline:
Bad step definition: inv (File not found or invalid) proj_create: Error
1029 (File not found or invalid): pipeline: Pipeline: Bad step
definition: inv (File not found or invalid) QGIS died on signal 11[New
LWP 587863] [New LWP 587862] [New LWP 587861] [New LWP 587860] [New LWP
587859] [New LWP 587858] [New LWP 587857] [New LWP 587856] [New LWP
587855] [New LWP 587854] [New LWP 587853] [New LWP 587827] [New LWP
587826] [New LWP 587825] [New LWP 587824] [New LWP 587823] [New LWP
587822] [New LWP 587821] [New LWP 587820] [New LWP 587819] [New LWP
587817] [New LWP 587816] [New LWP 587815] [New LWP 587814] [New LWP
587813] [New LWP 587805] [New LWP 587804] [New LWP 587803] [New LWP
587802] [New LWP 587801] [New LWP 587800] [New LWP 587799] [New LWP
587798] [New LWP 587797] [New LWP 587796] [New LWP 587795] [New LWP
587794] [New LWP 587793] [New LWP 587792] [New LWP 587791] [New LWP
587790] [New LWP 587789] [New LWP 587788] [New LWP 587787] [New LWP
587786] [New LWP 587785] [New LWP 587784] [New LWP 587777] [New LWP
587765] [New LWP 587762] [New LWP 587761] [New LWP 587760] [New LWP
587759] [New LWP 587758] [New LWP 587757] [New LWP 587754] [New LWP
587753] [New LWP 587752] [New LWP 587751] [New LWP 587750] [New LWP
587749] [New LWP 587748] [New LWP 587747] [New LWP 587746] [New LWP
587745] [New LWP 587743] [New LWP 587742] [New LWP 587741] [New LWP
587740] [New LWP 587739] [New LWP 587738] [Thread debugging using
libthread_db enabled] Using host libthread_db library
"/lib/x86_64-linux-gnu/libthread_db.so.1". __syscall_cancel_arch () at
../sysdeps/unix/sysv/linux/x86_64/syscall_cancel.S:56 warning: 56
../sysdeps/unix/sysv/linux/x86_64/syscall_cancel.S: No such file or
directory [Current thread is 1 (Thread 0x7f4256818180 (LWP 587724))] #0
../sysdeps/unix/sysv/linux/x86_64/syscall_cancel.S:56 #1
0x00007f4271a9b668 in __internal_syscall_cancel (a1=<optimized out>,
a2=<optimized out>, a3=<optimized out>, a4=<optimized out>,
a5=a5 at entry=0, a6=a6 at entry=0, nr=61) at ./nptl/cancellation.c:49 result
= <optimized out> pd = <optimized out> ch = <optimized out> #2
0x00007f4271a9b6ad in __syscall_cancel (a1=<optimized out>,
a5=a5 at entry=0, a6=a6 at entry=0, nr=61) at ./nptl/cancellation.c:75 r =
<optimized out> #3 0x00007f4271b067c7 in __GI___wait4 (pid=<optimized
out>, stat_loc=<optimized out>, options=<optimized out>,
usage=<optimized out>) at ../sysdeps/unix/sysv/linux/wait4.c:30 #4
0x00005642950c6a81 in ??? () #5 0x00007f4271a4bdf0 in <signal handler
called> () at /lib/x86_64-linux-gnu/libc.so.6 #6
__pthread_kill_implementation (threadid=<optimized out>,
signo=signo at entry=11, no_tid=no_tid at entry=0) at ./nptl/pthread_kill.c:44
tid = <optimized out> ret = 0 pd = <optimized out> old_mask = {__val =
{0}} ret = <optimized out> #7 0x00007f4271aa09ff in
__pthread_kill_internal (threadid=<optimized out>, signo=11) at
./nptl/pthread_kill.c:89 #8 0x00007f4271a4bcc2 in __GI_raise (sig=11) at
../sysdeps/posix/raise.c:26 ret = <optimized out> #9 0x00007f4271a4bdf0
in <signal handler called> () at /lib/x86_64-linux-gnu/libc.so.6 #10
0x00007f4277e6004b in
QgsPointCloudRendererPropertiesWidget::QgsPointCloudRendererPropertiesWidget(QgsPointCloudLayer*,
QgsStyle*, QWidget*) () at /lib/libqgis_gui.so.4.2.1 #11
0x00007f427944187e in ??? () at /lib/libqgis_app.so.4.2.1 #12
0x00007f42779de4f3 in
QgsLayerPropertiesDialog::addPropertiesPageFactory(QgsMapLayerConfigWidgetFactory
const*) () at /lib/libqgis_gui.so.4.2.1 #13 0x00007f42796aaeeb in
QgisApp::showLayerProperties(QgsMapLayer*, QString const&) () at
/lib/libqgis_app.so.4.2.1 #14 0x00007f42796ab3d5 in
QgisApp::layerProperties() () at /lib/libqgis_app.so.4.2.1 #15
0x00007f42721e4403 in ??? () at /lib/x86_64-linux-gnu/libQt6Core.so.6
#16 0x00007f4272af12a6 in QAction::triggered(bool) () at
/lib/x86_64-linux-gnu/libQt6Gui.so.6 #17 0x00007f4272af67b9 in
QAction::activate(QAction::ActionEvent) () at
/lib/x86_64-linux-gnu/libQt6Gui.so.6 #18 0x00007f4273b7e5dd in ??? () at
/lib/x86_64-linux-gnu/libQt6Widgets.so.6 #19 0x00007f4273b84781 in ???
() at /lib/x86_64-linux-gnu/libQt6Widgets.so.6 #20 0x00007f4273a04453 in
QWidget::event(QEvent*) () at /lib/x86_64-linux-gnu/libQt6Widgets.so.6
#21 0x00007f42739b49b5 in QApplicationPrivate::notify_helper(QObject*,
QEvent*) () at /lib/x86_64-linux-gnu/libQt6Widgets.so.6 #22
0x00007f42739b8c96 in QApplication::notify(QObject*, QEvent*) () at
/lib/x86_64-linux-gnu/libQt6Widgets.so.6 #23 0x00007f42758633d3 in
QgsApplication::notify(QObject*, QEvent*) () at
/lib/libqgis_core.so.4.2.1 #24 0x00007f4272196570 in
QCoreApplication::notifyInternal2(QObject*, QEvent*) () at
/lib/x86_64-linux-gnu/libQt6Core.so.6 #25 0x00007f42739aeb9e in
QApplicationPrivate::sendMouseEvent(QWidget*, QMouseEvent*, QWidget*,
QWidget*, QWidget**, QPointer<QWidget>&, bool, bool) () at
/lib/x86_64-linux-gnu/libQt6Widgets.so.6 #26 0x00007f4273a1b2a8 in ???
() at /lib/x86_64-linux-gnu/libQt6Widgets.so.6 #27 0x00007f4273a1e148 in
??? () at /lib/x86_64-linux-gnu/libQt6Widgets.so.6 #28
QEvent*) () at /lib/x86_64-linux-gnu/libQt6Widgets.so.6 #29
0x00007f42758633d3 in QgsApplication::notify(QObject*, QEvent*) () at
/lib/libqgis_core.so.4.2.1 #30 0x00007f4272196570 in
/lib/x86_64-linux-gnu/libQt6Core.so.6 #31 0x00007f42727dfbc5 in
QGuiApplicationPrivate::processMouseEvent(QWindowSystemInterfacePrivate::MouseEvent*)
() at /lib/x86_64-linux-gnu/libQt6Gui.so.6 #32 0x00007f427283945c in
QWindowSystemInterface::sendWindowSystemEvents(QFlags<QEventLoop::ProcessEventsFlag>)
() at /lib/x86_64-linux-gnu/libQt6Gui.so.6 #33 0x00007f42566603be in ???
() at /lib/x86_64-linux-gnu/libQt6XcbQpa.so.6 #34 0x00007f425fdbb3c5 in
??? () at /lib/x86_64-linux-gnu/libglib-2.0.so.0 #35 0x00007f425fdbd5f7
in ??? () at /lib/x86_64-linux-gnu/libglib-2.0.so.0 #36
0x00007f425fdbdd60 in g_main_context_iteration () at
/lib/x86_64-linux-gnu/libglib-2.0.so.0 #37 0x00007f42723a6563 in
QEventDispatcherGlib::processEvents(QFlags<QEventLoop::ProcessEventsFlag>)
() at /lib/x86_64-linux-gnu/libQt6Core.so.6 #38 0x00007f4272198853 in
QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) () at
/lib/x86_64-linux-gnu/libQt6Core.so.6 #39 0x00007f4273b891ed in ??? ()
at /lib/x86_64-linux-gnu/libQt6Widgets.so.6 #40 0x00007f4273b89350 in
QMenu::exec(QPoint const&, QAction*) () at
/lib/x86_64-linux-gnu/libQt6Widgets.so.6 #41 0x00007f42780a337c in
QgsLayerTreeView::contextMenuEvent(QContextMenuEvent*) () at
/lib/libqgis_gui.so.4.2.1 #42 0x00007f4273a0485f in
#43 0x00007f4273a9dd46 in QFrame::event(QEvent*) () at
/lib/x86_64-linux-gnu/libQt6Widgets.so.6 #44 0x00007f4272195e1a in
QCoreApplicationPrivate::sendThroughObjectEventFilters(QObject*,
QEvent*) () at /lib/x86_64-linux-gnu/libQt6Core.so.6 #45
0x00007f42739b49a5 in QApplicationPrivate::notify_helper(QObject*,
QEvent*) () at /lib/x86_64-linux-gnu/libQt6Widgets.so.6 #46
0x00007f42739ba054 in QApplication::notify(QObject*, QEvent*) () at
/lib/x86_64-linux-gnu/libQt6Widgets.so.6 #47 0x00007f42758633d3 in
/lib/libqgis_core.so.4.2.1 #48 0x00007f4272196570 in
/lib/x86_64-linux-gnu/libQt6Core.so.6 #49 0x00007f4273a1aeba in ??? ()
at /lib/x86_64-linux-gnu/libQt6Widgets.so.6 #50 0x00007f4273a1e148 in
??? () at /lib/x86_64-linux-gnu/libQt6Widgets.so.6 #51
QEvent*) () at /lib/x86_64-linux-gnu/libQt6Widgets.so.6 #52
/lib/libqgis_core.so.4.2.1 #53 0x00007f4272196570 in
/lib/x86_64-linux-gnu/libQt6Core.so.6 #54 0x00007f42727dfbc5 in
() at /lib/x86_64-linux-gnu/libQt6Gui.so.6 #55 0x00007f427283945c in
() at /lib/x86_64-linux-gnu/libQt6Gui.so.6 #56 0x00007f42566603be in ???
This file warning: 56
directory I cannot find it in any package.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20260804/61baa122/attachment-0001.htm>
More information about the QGIS-User
