[Qgis-user] when I try to look at the properties of a layer which did not load, qgis crashes
Don Harter
harterc2 at att.net
Fri Aug 7 09:10:06 PDT 2026
The file for the layer that is not recognized appears to not be in a
proper format, but that should not crash qgis.
gdalinfo manhole_ground.las
ERROR 4: `manhole_ground.las' not recognized as being in a supported
file format.
gdalinfo failed - unable to open 'manhole_ground.las'.
file manhole_ground.las
manhole_ground.las: LIDAR point data records, version 1.3, SYSID
WhiteboxTools by John Lindsay WhiteboxTools \011\001\345\007\353,
Generating Software WhiteboxTools \011\001\345\007\353
On 8/4/26 8:31 PM, Don Harter via QGIS-User wrote:
> QGIS version
> 4.2.1-Belém do Pará
> qgis 2026-08-04 20:29:30,471 - QuickOSM - INFO - Plugin loaded with
> version : 2.5.3 proj_create: Error 1029 (File not found or invalid):
> pipeline: Pipeline: Bad step definition: inv (File not found or
> invalid) proj_create: Error 1029 (File not found or invalid):
> invalid) QGIS died on signal 11[New LWP 587863]
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20260807/19d25b7b/attachment.htm>
More information about the QGIS-User
