[Qgis-user] when I try to look at the properties of a layer which did not load, qgis crashes
Randal Hale rjhale at northrivergeographic.com
Fri Aug 7 09:51:52 PDT 2026
What happens if you do "pdal info manhole_ground.las"
On 8/7/26 12:10 PM, Don Harter via QGIS-User wrote:
> The file for the layer that is not recognized appears to not be in a
> proper format, but that should not crash qgis.
> gdalinfo manhole_ground.las
> ERROR 4: `manhole_ground.las' not recognized as being in a supported
> file format.
> gdalinfo failed - unable to open 'manhole_ground.las'.
> file manhole_ground.las
> manhole_ground.las: LIDAR point data records, version 1.3, SYSID
> WhiteboxTools by John Lindsay   WhiteboxTools  \011\001\345\007\353,
> Generating Software WhiteboxTools            \011\001\345\007\353
> On 8/4/26 8:31 PM, Don Harter via QGIS-User wrote:
>> QGIS version
>> 4.2.1-Belém do Pará
>> qgis 2026-08-04 20:29:30,471 - QuickOSM - INFO - Plugin loaded with
>> version : 2.5.3 proj_create: Error 1029 (File not found or invalid):
>> pipeline: Pipeline: Bad step definition: inv (File not found or
>> invalid) proj_create: Error 1029 (File not found or invalid):
>> invalid) QGIS died on signal 11[New LWP 587863]
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
North River Geographic Systems, Inc
(423) 653-3611
https://northrivergeographic.com
https://training.northrivergeographic.com
https://qgis-us.org
https://geohipster.com
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20260807/94a32db2/attachment.htm>
More information about the QGIS-User mailing list
