[Qgis-user] Update QGIS-Desktop
Blöcher, Ralf R.Bloecher at traffiQ.de
Fri Aug 14 03:05:26 PDT 2026
If I have version 3.34 installed and manually install version 3.44 over it, a second instance is also created. So this has nothing to do with the software distribution solution.
Is there a way to download the latest QGIS LTR version and then install it over an existing version?
i.A. Ralf Blöcher
Informationstechnologie
E-Mail r.bloecher at traffiq.de
traffiQ
Lokale Nahverkehrsgesellschaft Frankfurt am Main mbH
Stiftstr. 9 - 17
60313 Frankfurt am Main
Geschäftsführer: Prof. Dr.-Ing. Tom Reinhold
Aufsichtsratsvorsitzender: Stadtrat Wolfgang Siefert
Amtsgericht Frankfurt am Main - HRB 42452
USt-ID: DE187077253
www.traffiQ.de
-----Ursprüngliche Nachricht-----
Von: QGIS-User <qgis-user-bounces at lists.osgeo.org> Im Auftrag von Greg Troxel via QGIS-User
Gesendet: Freitag, 14. August 2026 11:26
An: Blöcher, Ralf via QGIS-User <qgis-user at lists.osgeo.org>
Betreff: Re: [Qgis-user] Update QGIS-Desktop
"Blöcher, Ralf via QGIS-User" <qgis-user at lists.osgeo.org> writes:
> I have a question about QGIS Desktop and updating to a new version.
> We install QGIS Desktop using a software distribution tool called PDQ Deploy. We use this to install the QGIS-OSGeo4W-3.34.11-1_LTR.msi file remotely on Windows clients.
> If I simply install the  new Version QGIS-OSGeo4W-3.44.12-1_LTR.msi file 'over' version 3.34, a second instance of QGIS is installed on the computer.
> But how can I remotely update version 3.34.11-1_LTR to version QGIS-OSGeo4W-3.44.12-1_LTR.msi using a software deployment tool without installing a second instance?
This question is about "PDQ Deploy", which appears to be a paid-for, proprietary tool.  I suggest you address questions about PDQ Deploy not doing what you want to your PDQ support contacts.
QGIS-User mailing list
QGIS-User at lists.osgeo.org
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
More information about the QGIS-User mailing list
