[Qgis-user] Amal Kar - NOAA_CLASS AVHRR-LAC-1km Satellite Data reading by QGIS (ver. 3.28.15)-About
Andrea Giudiceandrea andreaerdna at libero.it
Sat Aug 15 04:33:57 PDT 2026
Hi Amal,
first of all please consider that you are using a 2 years old QGIS
version which is very likely also using an old version of the GDAL
library depending on the Operative System (which one exactly) and on the
installer/binaries (which one exactly) used.
Have you tried if the issue occurs also using a currently supported QGIS
version using a recent version of the GDAL library?
Have you tried if the issue occurs directly using the GDAL tool gdalinfo?
If the issue occurs directly using the GDAL tool gdalinfo, then I would
suggest you to file an issue report on the GitHub repository of the GDAL
library, otherwise on the GitHub repository of QGIS, providing both a
layer file for which the issue occurs and a layer file for which the
issue doesn't occur.
Best regards.
Andrea
More information about the QGIS-User mailing list
