[Qgis-user] Error code: 203
Helene Engehagen
heen1961 at edu.kglakademi.dk
Tue Feb 3 00:12:49 PST 2026
Hi!
I’m having an issue with the Dataforsyningen plugin in QGIS and was hoping someone could help.
I’ve installed the plugin and added a new token, but I get the following error:
WARNING No contact to the configuration at https://qgisplugin.dataforsyningen.dk/qgis_plugin_dataforsyningen_udentoken.qlr. Error code: 203
I suspect the issue might be related to how Processing outputs are linked, but I can’t change the paths because I can’t get further into the plugin/application.
Current Processing output path:
/Users/name/Desktop
Expected path (I think):
/Users/name/Library/Application Support/QGIS/QGIS3/profiles/default/processing/outputs
I’m running QGIS 3.44.7 (Solothurn) on macOS Tahoe 26.2.
Has this happend before, or do you know what might be causing it?
Best regards
Helene
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20260203/96b8b26f/attachment.htm>
More information about the QGIS-User
