[Qgis-user] Error code: 203
Alexander Bruy alexander.bruy at gmail.com
Tue Feb 3 00:20:41 PST 2026
Hi Helene,
This is not related to QGIS at all. It seems that the URL is broken
(it returns 404 when you try to access it)
and the plugin fails to handle this. You should contact plugin
developers about this issue.
вт, 3 лют. 2026 р. о 08:13 Helene Engehagen via QGIS-User
<qgis-user at lists.osgeo.org> пише:
> Hi!
> I’m having an issue with the Dataforsyningen plugin in QGIS and was hoping someone could help.
> I’ve installed the plugin and added a new token, but I get the following error:
> WARNING No contact to the configuration at https://qgisplugin.dataforsyningen.dk/qgis_plugin_dataforsyningen_udentoken.qlr. Error code: 203
> I suspect the issue might be related to how Processing outputs are linked, but I can’t change the paths because I can’t get further into the plugin/application.
> Current Processing output path:
> /Users/name/Desktop
> Expected path (I think):
> /Users/name/Library/Application Support/QGIS/QGIS3/profiles/default/processing/outputs
> I’m running QGIS 3.44.7 (Solothurn) on macOS Tahoe 26.2.
> Has this happend before, or do you know what might be causing it?
> Best regards
> Helene
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
Alexander Bruy
More information about the QGIS-User mailing list
