[Qgis-user] Issue with tmsforkorea Plugin on QGIS 3.44 (macOS)
Emma Hain emma at north-road.com
Thu Feb 5 16:48:54 PST 2026
Hi Jinsol
For plugins, you can always check which versions of QGIS they are up to
date for via the excellent QGIS Plugins site
<https://plugins.qgis.org/plugins/tmsforkorea/#plugin-versions>.
In this instance, it looks as if *tmsforkorea *is only supported up to
3.0.5. So you could use that version of QGIS to use the tool.
This list is for any QGIS Core support. For QGIS Plugins, it is best to
contact the developer so I would encourage you to submit an issue for this
on the GitHub
<https://github.com/mangosystem/qgis-tmsforkorea-plugin/issues>. It appears
that this has already been identified as an issue so you can add to it: TMS
for korea with qgis Latest version #8
<https://github.com/mangosystem/qgis-tmsforkorea-plugin/issues/8>
However, if the developer no longer wishes to work on the plugin then it
may need to be taken over by someone who does wish to develop it. This
could be something to be discussed in FOSS4G Korea
<https://foss4g.osgeo.kr/>.
Good luck
Em
On Fri, 6 Feb 2026 at 05:01, 김진솔 via QGIS-User <qgis-user at lists.osgeo.org>
wrote:
> Hello,
> I recently subscribed to this mailing list and apologize if this question
> is duplicated.
> I am using QGIS 3.44 on macOS, and I am experiencing an error when trying
> to use the "tmsforkorea" plugin:
> ImportError: cannot import name 'QtWebKitWidgets' from 'PyQt5'
> It seems that this plugin requires QtWebKit, which is no longer included
> in recent QGIS/PyQt versions on macOS.
> Since I need to use this plugin for a university project, I would
> appreciate any advice or workaround.
> Thank you very much.
> Best regards,
> Jinsol
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20260206/ff29a594/attachment.htm>
More information about the QGIS-User mailing list
