[Qgis-user] Issue with tmsforkorea Plugin on QGIS 3.44 (macOS)
Andrea Giudiceandrea andreaerdna at libero.it
Thu Feb 5 17:45:33 PST 2026
> Emma Hain emma at north-road.com
> Thu Feb 5 16:48:54 PST 2026
> In this instance, it looks as if *tmsforkorea *is only supported up to
> 3.0.5. So you could use that version of QGIS to use the tool.
Hi Emma and Jinsol,
actually "3.0.5" is the version number of the latest plugin version
released in May 2002.
The minimum QGIS version supported by such plugin version is QGIS 3.16.0.
In fact, I successfully installed the plugin "TMS for Korea" on the
latest QGIS LTR 3.40.15 and QGIS 3.44.7 on Windows (via OSGeo4W).
The issue in your case, as you already argued, is that the the
QtWebKitWidgets module is not available in the latest QGIS 3.44
installers for macOS provided by qgis.org.
IIRC, such module was present in the installers for mac OS until QGIS
3.42, so I guess you could successfully try to install the plugin in
QGIS 3.42 on macOS.
The latest QGIS 3.42 installer for macOS is
qgis_pr_final-3_42_1_20250324_153321.dmg available at
https://download.osgeo.org/qgis/mac/macos/pr/?C=M&O=D.
Regards.
Andrea
More information about the QGIS-User mailing list
